  3. Best ways to set Design for Manufacturing rules in the PCB...
  • Subscribers 166
  • Views 10714
Best ways to set Design for Manufacturing rules in the PCB design flow!
geda
geda over 3 years ago
Design for Manufacturing (DFM) checks is the practice of optimizing the design workflow. DFM checks are mandatory for the PCB to be fabricated without any potential manufacturing issues. When a PCB is first developed, the focus is usually on the functionality rather than the manufacturability of the board. Many issues are traditionally found in the cycle between design and sign-off to manufacturing. Performing DFM checks with the design will make the user aware of the time savings in catching these issues earlier in the cycle.
Various tools and techniques are available in the industry for this. Each company has its process in place to perform DFM checks. Any recommendations/methodologies that you would give to a new or existing user to improve the manufacturing process?
  1. After tape-out, get inputs from the fab house and then make suitable design changes.
  2. Use the DesignTrue DFM Wizard utility.
  3. Implement thorough DFM constraints check from within Allegro Constraint Manager.
  4. DFM Checker part of the Allegro Manufacturing Option.
  5. Third-party DFM checkers, for example, Valor.
We would like to hear your comments as it helps us know user requirements and market trends to influence longer-term product decisions.
    • AD1912
      AD1912 over 3 years ago
      Used all the three options 2,3 and 4 in my experience to some extent. Personally, prefer the DFM Constraints present within Allegro CM.
      They are more easy to define and use during the design cycle.
      Not had much experience on DFM tools from other EDA vendors
    • Schulz Jordan
      Schulz Jordan over 3 years ago
      Cadence once had tied up with manufacturers and provided a portal to Cadence users where they can upload design to get it checked for DFX checks along with cost of manufacturing. Does that facility still exist ?
    • steve
      steve over 3 years ago in reply to Schulz Jordan
      Yes it does DesignTrue DFM Program (cadence.com)
    • Jeff H
      Jeff H over 3 years ago
      I have been using DesignTrue DFM for about a year now with a lot of success.  In my opinion, you are better off building the configuration up from scratch than using the wizard so you understand exactly what is being done.  As we get TQs from the board house or DFM issue from our CM, we look at our DFM and DRC rules to see if we could have caught the issue by updating the rule.  If we can't find a way to automatically check for it, the issues goes into our manual checklist until we can find a way to automatically check for it.  Since we started doing this process, our TQ/DFMs have gone way down
    • Jeff H
      Jeff H over 3 years ago in reply to steve
      The funny thing about this portal, a few years ago I sent a request to Summit and I got an email back from Gerry Partida (Vice President of Technology at Summit Interconnect) and he told me that he kept getting these requests, but nobody knew what they were Slight smile
