  3. New user and older versions of Cadence
  • State Verified Answer
  • Views 10679
mccorm14
mccorm14 over 3 years ago
I'm helping install a new version of Cadence (22.1) and the current version on the machine is version 17.2. The user asked me if they'll still be able to open files created on version 17.2 on the new version 22.1. I'm new to this application and I wanted to check in case I were to have compatibility problems. I appreciate any information, thank you!
  • Vipulc
    Vipulc over 3 years ago +2 verified
    Yes, you can open 17.2 database in 22.1. I will recommend you to take a backup of 17.2 database before opening database in 22.1. If 17.2 database is opened in 22.1 as saved then this cannot be opened…
  • Vipulc
    +1 Vipulc over 3 years ago
    If 17.2 database is opened in 22.1 as saved then this cannot be opened in 17.2 without a "Downrev Design".
    Downrev functionality is available in 22.1 (File > Export Downrev Design...)
    • Vote Up +2 Vote Down
  • mccorm14
    0 mccorm14 over 3 years ago in reply to Vipulc
    Thank you for the information! It worked perfectly, I really appreciate the help!
