  3. Drill hole size vs finished hole size chart
  • State Suggested Answer
  • Answers 1
  • Views 11935
PCB6453
PCB6453 over 3 years ago
On my drill chart, they all call out for the "finished size" for all holes (through hole, blind vias, and microvias).  The fabrication house that I talked to requested to have the drill size shown instead of the finished hole size for microvias only.  Is there a way to show the drill size instead of the finished hole size on the drill chart?  Or can I show both?
Thank you.
MG
  • masamasa
    masamasa over 3 years ago +1
    manunfacture --> nc --> drill customization on the menu shows u the drill customization dialog. it automatically generates the hold size and hole count. u can generate the report file in csv as well…
  • Daniel
    Daniel over 3 years ago +1 suggested
    Design Tool Size to using for fab
  • masamasa
    0 masamasa over 3 years ago
    u can generate the report file in csv as well.
  • PCB6453
    0 PCB6453 over 3 years ago in reply to masamasa
    Masamasa,
    I was hoping to generate a chart that calls for "Drill_Size" for the microvias without me having to manually change it all the time.  For now, I change the "FINISHED_SIZE" to "DRILL_SIZE" for the microvias.
  • Daniel
    0 Daniel over 3 years ago
  • PCB6453
    0 PCB6453 over 3 years ago in reply to Daniel
    Thank you.
