  3. Dangling Via Report
  • State Suggested Answer
  • Replies 11
  • Answers 3
  • Subscribers 167
  • Views 13782
Dangling Via Report
karthikeyank
karthikeyank over 3 years ago
HI,
i want to find out the dangling via location by using cadence skill program. Can anyone please help me out.
prog;
procedure(chk()
axlClearSelSet()
axlSetFindFilter(?enabled `("NOALL" "VIAS") ?onButtons `("VIAS"))
via_data = axlGetSelSet(axlAddSelectAll())
foreach(via_data_lp via_data
                     if(via_data_lp->unconnected then
                       print(via_data_lp->net->name)
                       print(via_data_lp->xy)
  • luanvn81
    luanvn81 over 3 years ago +1
    Hi karthikeyank You can find dangling via by using tool\report\Dangling Line, Via and Antenna Report. You can also create code to do it, but I think there is not via's attribute named " unconnected"…
  • AsbjornEdvalds
    AsbjornEdvalds over 3 years ago +1 suggested
    Hi, Like Luan said, you can get this report from the report menu. However, if you want to do this by using skill, you can use the axlDBGetConnect() command. I.e. replace your via_data_lp->unconnected…
  • karthikeyank
    karthikeyank over 3 years ago in reply to AsbjornEdvalds +1
    Thanks you..
  • luanvn81
    0 luanvn81 over 3 years ago
    Hi karthikeyank
     You can find dangling via by using tool\report\Dangling Line, Via and Antenna Report. You can also create code to do it, but I think there is not via's attribute named "unconnected".
    Luan
  • AsbjornEdvalds
    0 AsbjornEdvalds over 3 years ago
    I.e. replace your
    with
    length(axlDBGetConnect(via_data_lp t))<2
    which finds all vias with less than two connections
  • karthikeyank
    0 karthikeyank over 3 years ago in reply to AsbjornEdvalds
    Thanks you..
  • karishma
    0 karishma over 2 years ago in reply to AsbjornEdvalds
    length(axlDBGetConnect(via_data_lp t))<2 using this code I was able to get the vias with single connection. When I try this code the dangling vias are getting deleted but some unintentional vias are also getting deleted. I want to find the list of dangling vias from the vias list and delete them.If any suggestions .Please help me.
    foreach(via l_vias
        len = length(axlDBGetConnect(via)); connections connected to via
        if(len == 1 then ; checks if via has 1 connection
                if(via->net->name != nil then ;checks if via has net name
                      via_loc = via->xy
                      axlDeleteObject(via)
                  );endif
           );endif
    );end foreach
  • luanvn81
    0 luanvn81 over 2 years ago in reply to karishma
    Hi guy!
    Try this :
    axlCmdRegister( "dvr" `dvr) ;dangling_via_report
    (defun dvr ()
    originalVisible = axlVisibleGet()
    designName = axlCurrentDesign()
    design_path = axlGetDrawingName()
    design_unit = car(axlDBGetDesignUnits())
    Drc = 0
    axlSetFindFilter(?enabled '(noall VIAS) ?onButtons '(noall VIAS))
    l_vias = axlGetSelSet(axlAddSelectAll())
    axlClearSelSet()
    writeOutFile = outfile("./dangling_via_report.log" "w")
    fprintf(writeOutFile, "Design name: %s\n", design_path)
    fprintf(writeOutFile, "%s %s\n", "Date: ", timeToString(fileTimeModified("dangling_via_report.log")))
    fprintf(writeOutFile, "%s\n", "-------------------------------------------------------------------------------------------------")
    fprintf(writeOutFile "%-24s %-24s %-20s\n\n", "Via_NetName", "Via name", "Location")
    foreach(via l_vias
    if(length(axlDBGetConnect(via t)) == 1 && via->net->name != nil then ; checks if via has 1 connection
    ;axlDeleteObject(via)
    fprintf(writeOutFile, "%-24s %-24s %L \n", via->net->name, via->name, via->xy)
    Drc = Drc + 1
    );endif
    Luan
    );end foreach
    fprintf(writeOutFile "END OF FILE\n")
    close(writeOutFile)
    if(Drc > 0 then
    logWindow = axlUIViewFileCreate("dangling_via_report.log", "antenna via report..." nil )
    else
    axlUIConfirm( "No Error found.")
    printf("No error found\n")
    if(isFile("dangling_via_report.log") == t then deleteFile("dangling_via_report.log"));end if
    ); end if count_drc
    );end defun dvr
