  3. Dangling Via Report
  • State Suggested Answer
  • Replies 11
  • Answers 3
  • Subscribers 167
  • Views 13783
Dangling Via Report
karthikeyank
karthikeyank over 3 years ago
HI,
i want to find out the dangling via location by using cadence skill program. Can anyone please help me out.
prog;
procedure(chk()
axlClearSelSet()
axlSetFindFilter(?enabled `("NOALL" "VIAS") ?onButtons `("VIAS"))
via_data = axlGetSelSet(axlAddSelectAll())
foreach(via_data_lp via_data
                     if(via_data_lp->unconnected then
                       print(via_data_lp->net->name)
                       print(via_data_lp->xy)
  • luanvn81
    luanvn81 over 3 years ago +1
    Hi karthikeyank You can find dangling via by using tool\report\Dangling Line, Via and Antenna Report. You can also create code to do it, but I think there is not via's attribute named " unconnected"…
  • AsbjornEdvalds
    AsbjornEdvalds over 3 years ago +1 suggested
    Hi, Like Luan said, you can get this report from the report menu. However, if you want to do this by using skill, you can use the axlDBGetConnect() command. I.e. replace your via_data_lp->unconnected…
  • karthikeyank
    karthikeyank over 3 years ago in reply to AsbjornEdvalds +1
    Thanks you..
  • karishma
    0 karishma over 2 years ago in reply to luanvn81
    Hi Luan,
    Can you explain why we are using Drc > 0 variable conditional loop at the end .
    There's no function call deleteFile in api documentation
    Please elaborate this part of code :
    if(Drc > 0 then
    logWindow = axlUIViewFileCreate("dangling_via_report.log", "antenna via report..." nil )
    else
    axlUIConfirm( "No Error found.")
    printf("No error found\n")
    if(isFile("dangling_via_report.log") == t then deleteFile("dangling_via_report.log"));end if
    ); end if count_drc
  • AsbjornEdvalds
    0 AsbjornEdvalds over 2 years ago in reply to karishma
    The DRC>0 condition is to only generate and show a window that shows the report "dangling_via_report" generated above. If there are no errors, there is no reason to show the file.
    The deleteFile can be found in the sklanguser documentation under the I/O and File Handling chapter.
  • karishma
    0 karishma over 2 years ago in reply to AsbjornEdvalds
    I need to get dangling vias list same as the dangling vias quick report using allegro skill.I have below code but it's not working.I am new to skill Please help me.
    foreach(via l_vias
    len = length(axlDBGetConnect(via)); connections connected to via
    ;fprintf(repfile "Found Via %L with Net name %L connections %d\n" via->xy via->net->name len)
    if(len == 1 then ; a lonely cline is connected to a via
    conn_obj = car(axlDBGetConnect(via))
    if(conn_obj->net->name == nil then
    via_loc = via->xy
    fprintf(repfile "Found Via with one connection at %L on a net %L \n" via_loc via->net->name)
    ;axlDeleteObject(via)
    );endif
    );endif
    );end foreach
  • DE202408202727
    0 DE202408202727 over 2 years ago in reply to karishma
    You have changed != to == so you will never see vias with a net.
    Your simplified code would be:
    foreach(via l_vias
      when(onep(length(axlDBGetConnect(via))) ; a lonely cline is connected to a via
        fprintf(repfile "Found Via with one connection at %L on a net %L \n" via->xy via->net->name)
      );end when
    );end foreach
  • karishma
    0 karishma over 2 years ago in reply to DE202408202727
    Hi Dave,
    I need to get dangling vias list same as it's generated using quick reports
    Using the above code I am able to get the vias with one connection, but some other vias are also getting listed apart from dangling vias list from quick reports.
    how can we get the dangling vias list same as quick reports. Please suggest
