  3. Dangling Via Report
  • State Suggested Answer
  • Replies 11
  • Answers 3
  • Subscribers 167
  • Views 13789
Dangling Via Report
karthikeyank
karthikeyank over 3 years ago
HI,
i want to find out the dangling via location by using cadence skill program. Can anyone please help me out.
prog;
procedure(chk()
axlClearSelSet()
axlSetFindFilter(?enabled `("NOALL" "VIAS") ?onButtons `("VIAS"))
via_data = axlGetSelSet(axlAddSelectAll())
foreach(via_data_lp via_data
                     if(via_data_lp->unconnected then
                       print(via_data_lp->net->name)
                       print(via_data_lp->xy)
  • luanvn81
    luanvn81 over 3 years ago +1
    Hi karthikeyank You can find dangling via by using tool\report\Dangling Line, Via and Antenna Report. You can also create code to do it, but I think there is not via's attribute named " unconnected"…
  • AsbjornEdvalds
    AsbjornEdvalds over 3 years ago +1 suggested
    Hi, Like Luan said, you can get this report from the report menu. However, if you want to do this by using skill, you can use the axlDBGetConnect() command. I.e. replace your via_data_lp->unconnected…
  • karthikeyank
    karthikeyank over 3 years ago in reply to AsbjornEdvalds +1
    Thanks you..
  • DE202408202727
    0 DE202408202727 over 2 years ago in reply to karishma
    Try this:
    foreach(via, l_vias
    n = length(axlDBGetConnect(via))
    when(n < 2 ; Fewer than two clines are connected to a via
    viaPads = setof(pad, via ->pads, car(parseString(pad ->layer, "/")) == "ETCH" && pad ->type == "REGULAR")
    viaPadsInPlanes = setof(pad, viaPads, exists(shp, axlDBGetShapes(pad ->layer), shp ->net == via ->net && axlGeoPointInShape(via ->xy, shp)))
    n = n + length(viaPadsInPlanes)
    when(n < 2; Fewer than two clines or etch shapes are connected to a via
    pins = axlPinsOfNet(via ->net, 'pin)
    viaPads = setof(pad, viaPads, !member(pad, viaPadsInPlanes))
    viaPadsInPinPads = setof(viaPad, viaPads, exists(pin, pins, axlGeoPointInShape(via ->xy, car(axlPolyFromDB(pin, ?layer viaPad ->layer, ?padType "REGULAR")))))
    n = n + length(viaPadsInPinPads)
    when(n < 2; Fewer than two clines, etch shapes or pins are connected to a via
    printf("Found Via with one connection at %L on a net %L \n", via->xy, via->net->name)
    ;fprintf(repfile "Found Via with one connection at %L on a net %L \n", via->xy, via->net->name)
    );end when
    );end foreach
