  3. ODB++ Inside not working
  • State Suggested Answer
  • Answers 1
  • Subscribers 166
  • Views 11002
gazza47
gazza47 over 3 years ago
I'm trying to export ODB++ Files from Cadence but it doesn't appear o be working as it gives an error.
I'm running Cadence 17-4 and have tried installing ODB Inside cadence Allegro 115 and 2305
The error message states brd2odb.exe has errors
Has anyone seen this issue and know how to resolve
  • oldmouldy
    oldmouldy over 3 years ago +1 suggested
    Check that the Artwork, Gerber, generates without issue. Issues will Gerber generation will impact ODB++ generation since the Artwork setup is used to determine what data gets generated for ODB++. There…
  • oldmouldy
    0 oldmouldy over 3 years ago
    Check that the Artwork, Gerber, generates without issue. Issues will Gerber generation will impact ODB++ generation since the Artwork setup is used to determine what data gets generated for ODB++. There should be a log file, that may help. Otherwise, the ODB++ Inside application is a Siemens, Mentor Graphics, product and they have support links from the ODB++ site.
  • TCHA
    0 TCHA over 3 years ago in reply to oldmouldy
    @gazza47, is the issue resolved?
  • masamasa
    0 masamasa over 3 years ago
    u can try this
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nbsREAQ
