  3. gerber out question
  • State Verified Answer
  • Subscribers 166
  • Views 7812
gerber out question
masamasa
masamasa over 3 years ago
hello
i would like to have an outline shape placed on "substrate geometry/outline" exported as gerber but the gerber file is empty and gives me the following warning.
how can i export the outline shape as gerber?
can the outline shape have no 0 width line?
should i convert the outline shape to a line?
how can i change a shpae to a line?
regards
masa
  • steve
    steve over 3 years ago +1 verified
    You could try setting the undefined line width for that artwork film to 0.001mm (or something similar) and see if that helps. If it doesn't use Shape - Decompose Shape then set the options pane as required…
  • steve
    +1 steve over 3 years ago
    You could try setting the undefined line width for that artwork film to 0.001mm (or something similar) and see if that helps. If it doesn't use Shape - Decompose Shape then set the options pane as required and convert the shape to lines. Give these a thickness (hover right click - Change Width) then try again,
  • masamasa
    0 masamasa over 3 years ago in reply to steve
    thank u steve as always.
    it worked.
