  3. DB Doctor 23.1 Download
  • State Verified Answer
  • Replies 16
  • Answers 2
  • Subscribers 172
  • Views 34096
gulur
gulur over 2 years ago
I am running 23.1-2023-S001 of OrCAD and would like the DB Doctor file. Can you please email it to me?
Tejas
  • John T
    John T over 2 years ago +1 suggested
    Based on these investigations we recommend users look for the dbdoctor_ui program in the OrCADX 23.1 installation folder: C:\Cadence\OrCADX_23.1\tools\bin (or wherever your Cadence folder resides on…
  • Nilanjan Talukder
    Nilanjan Talukder over 2 years ago in reply to John T +1 verified
    Hi John, They are in the same directory. Surprisingly when asked the vendor to provide with Version 17.2 or later version those I was able to upgrade to 23.1. Thanks, Nilanjan
  • Nilanjan Talukder
    0 Nilanjan Talukder over 2 years ago in reply to John T
    Hi John T,
    I am using 23.1 SPD and when I run DBdoctor. I get the following errors:
    Performing UPREV on the database - C:/Project/STRONGHOLD/s_r218t919m218_919.pad
    Performing dbdoctor16 to bring DB up to REV16
    ------------------------------ Terminal Output ---------------------------------
    C:\Project\STRONGHOLD>echo off
    '"C:\Users\xxx\Cadence"' is not recognized as an internal or external command,
    operable program or batch file.
    ERROR: Uprev of revision to REV16 found errors.
    Performing dbdoctor17 to bring DB up to REV17
    ERROR: Uprev of revision to REV17 found errors.
    ERROR: Uprev of design failed.
    I replaced account name with xxx.
    The design was last saved using 16.5.
  • Nilanjan Talukder
    0 Nilanjan Talukder over 2 years ago in reply to Nilanjan Talukder
    I can open the .dra file using Allegro but when I try to place the footprint on a .brd file I get error that .pads cant be found
  • John T
    0 John T over 2 years ago in reply to Nilanjan Talukder
    Hi Nianjan, but are those pad files available in the padpath folder? If not available in the design database already you will need those pad files exported and present in the relevant folder. Hope this helps
  • Nilanjan Talukder
    +1 Nilanjan Talukder over 2 years ago in reply to John T
    Hi John,
    Nilanjan
  • CB20250530285
    0 CB20250530285 over 1 year ago in reply to John T
    Hi john,
    We are trying to update an old board file saved using 16.6 on our 23.1 Version and get following error on DB Doctot
    Performing UPREV on the database - E:/g/MYB-YG2LX-V10-230406.brd
    Please help resolve this issue
    Chandra
