  3. PCB Editor 23.1, File -> Plot Setup -> Scaling factor have...
  • State Verified Answer
  • Replies 15
  • Views 10101
PCB Editor 23.1, File -> Plot Setup -> Scaling factor have some issues
Zhifeng Jin
Zhifeng Jin over 2 years ago
The 'File --> Plot' function of Allegro PCB Editor 23.1 seems to have some issues. I set the Scaling factor to 1 in 'File -- Plot Setup',
but when using Plot Print Preview, it still displays in the form of fit to page,
  • John T
    John T over 2 years ago in reply to Zhifeng Jin +1 verified
    Hi jinzhifend, upon review of the above thread, we feel that A Cadence Change Request (CCR) should be submitted on your behalf to address this problem. Please stand by as my colleagues and I will formally…
  • Zhifeng Jin
    Zhifeng Jin over 2 years ago in reply to John T +1
    Received, thank you very much. This issue has been resolved in 23.1 HF005
  • steve
    0 steve over 2 years ago
    This is working for me. I usually set this first in File - Plot Setup but can also adjust this in the File - Plot Preview window so make sure you are running the latest hotfix for the version of software you have. 17.4-2019 S039, 22.1-2022 S008 or 23.1-2023 S001. You can check from Help - About.
  • Zhifeng Jin
    0 Zhifeng Jin over 2 years ago in reply to steve
    Yes, I first set A3 in the File - Plot Setup,The picture above is just to show you the paper size I currently set. This problem currently appears in 23.1-2023 base and 23.1-2023 S001. In the previous version of 22.1-2022 S008, I tried without this issues. If you also installed this version, you can test it.
  • Zhifeng Jin
    Hi, brothers, is there a way to solve it?
  • steve
    0 steve over 2 years ago in reply to Zhifeng Jin
    There appears to be nothing to solve - this just works!! A3 Portrait set, scaled to 1 in Plot Setup....
  • Zhifeng Jin
    What is your software version? Can I take a screenshot of your plot setup?
