  3. Allegro Design 17.4 After revising pad stack, what is preventing...
  • State Suggested Answer
  • Replies 8
  • Answers 2
  • Views 10305
Allegro Design 17.4 After revising pad stack, what is preventing me from updating the pad stack in the design?
avant
avant over 2 years ago
Symbols are not locked or fixed.
I cannot update revised pad stack in design. I have to save the pad stack, then perform a pad stack replace function in the design.
  • mahimag
    mahimag over 2 years ago in reply to avant +1 suggested
    You can try using batch commands, This can be done with the command refresh_padstack that can be run on the OS command line. for %f IN (*.dra) DO refresh_padstack -d %f
  • mahimag
    Hello avant , it might be design specific issue. Run the Database Check on the board. I can have a further look into it if you can share the design and pad!!
  • Wild
    0 Wild over 2 years ago in reply to avant
    I am on 17.2 - To do this I go to tools -> Padstack -> Modify Design Padstack.  Then chose the padstack to modify.  Edit it.  This will update all instances of that padstack in the current design and not the library.  I hope this helps
  • avant
    0 avant over 2 years ago in reply to Wild
    It has always worked that way. After editing, select "update to design" within the editor. This does not work on the 17.4 version I have installed.
    I can save the edited padstack, close the padstack editor, and then replace the padstack on the board. At the end of the day, these extra steps add cost.
  • mahimag
    0 mahimag over 2 years ago in reply to avant
    Hello avant, it might be design specific issue. Run the Database Check on the board. I can have a further look into it if you can share the design and pad!!
