  3. Allegro Design 17.4 After revising pad stack, what is preventing...
  • State Suggested Answer
  • Replies 8
  • Answers 2
  • Views 10304
Allegro Design 17.4 After revising pad stack, what is preventing me from updating the pad stack in the design?
avant
avant over 2 years ago
Symbols are not locked or fixed.
I cannot update revised pad stack in design. I have to save the pad stack, then perform a pad stack replace function in the design.
  • mahimag
    mahimag over 2 years ago in reply to avant +1 suggested
    You can try using batch commands, This can be done with the command refresh_padstack that can be run on the OS command line. for %f IN (*.dra) DO refresh_padstack -d %f
  • mahimag
    Hello avant , it might be design specific issue. Run the Database Check on the board. I can have a further look into it if you can share the design and pad!!
  • mahimag
    0 mahimag over 2 years ago
    Hello avant, have you tried refreshing the padstacks from Tools > Padstack > Refresh command?
    Make sure to  enable the "reset customizable drill data" in the Refresh Padstack dialog box. Some data like Drill tolerance will not be updated if this is not selected.
  • avant
    0 avant over 2 years ago in reply to mahimag
    I am trying to understand why this time-saving function does not work in 17.4
  • mahimag
    0 mahimag over 2 years ago in reply to avant
  • avant
    I am asking about using the padstack editor to edit a padstack in a design, and then updating the design from the padstack editor.
  • avant
    To clarify, I am asking about using the padstack editor to edit a padstack in a design, and then updating the design from the padstack editor.
    I am creating Gerbers from JEDEC designs that have undefined flash symbols. I don't want to extract all of the padstacks and I don't want our libraries polluted with these padstacks, and I don't want to waste a lot of time doing this. This function has always worked in previous versions, but not in 17.4. I'm trying to figure out why.
