  3. Is ECAD-MCAD collaboration possible between OrCAD 17.4 and...
  • State Suggested Answer
  • Answers 1
  • Subscribers 166
  • Views 8536
Is ECAD-MCAD collaboration possible between OrCAD 17.4 and Catia V5?
kevcon
kevcon over 2 years ago
If it is possible what is needed to make it happen and are there any tutorials/user guides on how to set it up?
  • PatEscher
    PatEscher over 2 years ago in reply to kevcon +1 suggested
    SPB 17.4 is quite old and as far as I know it will be end of support soon (Just have a look at the Lifetime documents in the Cadence support portal) CATIA V5 does only support IDF 3.0. There is no support…
  • Robert Finley
    0 Robert Finley over 2 years ago
    Years ago, I worked for a shop using everything but Solidworks trying to get them to abandon P*DS.  Google isn't showing anything for IDX with Catia.  Large companies (laptops) use Siemens NX with a third-party IDX interface related to Autodesk Maya.
    Can you import Solidworks subassemblies in Catia V5?
    There is a complete solution available for Solidworks:   EMA-EDA's CadSync.  True bidirectional mechanical design.   Start a board assembly in SW, add mechanical parts (mtg holes/connectors/indicators), import it to Allegro/Orcad using CadSync (the mechanism to include refdes properties from SW.)  Import a schematic to it.
    I own SW professional but I think it works with standard SolidWorks so you won't need CircuitWorks.
  • kevcon
    0 kevcon over 2 years ago in reply to Robert Finley
    Catia V5 is the only MCAD tool we use here.
    Do Cadence people chime in on questions or is it strictly users here?
  • PatEscher
    0 PatEscher over 2 years ago in reply to kevcon
    CATIA V5 does only support IDF 3.0. There is no support for IDX and there is no plan for it as far I know.
    3DEXPERIENCE CATIA does support IDF and IDX and is working very well with Allegro through the file based IDX based collaboration.
    Please note that there is a press release from this year about a partnership between CADENCE and DASSAULT SYSTEMES.
    https://www.cadence.com/en_US/home/company/newsroom/press-releases/pr/2024/cadence-and-dassault-systemes-unveil-the-first-cloud-enabled.html
    Hope this helps
    Patrick
    P.S.: Disclaimer, I am a 3DS employee. If you need more information let me know and send me a private message.
  • kevcon
    0 kevcon over 2 years ago in reply to PatEscher
    Hi Patrick,
    Thank you for your reply, I had a feeling that was the case, unfortunately we are at the mercy of what our customers use as far as Catia goes.
    I have heard through the grapevine that we are planning to switch to 3DEXPERIENCE Catia, but it will probably not be until sometime in 2025 so that should make the ECAD/MCAD collaboration a bit easier for some projects.
    OrCAD is easier, we should be able to upgrade that with no issue, one out of two for now ain't bad I guess. Slight smile
    Kevin
