  3. contracting shapes with voids
  • State Verified Answer
  • Views 6826
masamasa
masamasa over 2 years ago
hello
i have a rectangular shape with a void as shown below.
i would like to contract the void only by x amount all around without changing the size of the shape as shown below.
how can i do it?
  • avant
    avant over 2 years ago +1 verified
    Use select shape to select the void, then edit the void.
  • techiecs
    techiecs over 2 years ago +1 verified
    Try the below suggested steps- 1 In the Options Tab, select or make the Boundary Class visible. 2 In the Find filter, enable the 'Voids/Cavities' objects and hover your cursor over a void, the void is…
  • masamasa
    masamasa over 2 years ago in reply to techiecs +1
    thank u for ur response. i was able to offset a void only in a shape. i did not know there was a void item in the ffind filter. regards masa
  • avant
    +1 avant over 2 years ago
  • techiecs
    +1 techiecs over 2 years ago
    2 In the Find filter, enable the 'Voids/Cavities' objects and hover your cursor over a void, the void is highlighted.
    3 Right-click and choose 'Expand/Contract'.
    4 Set value in the Options tab which in your case would be the 'x'.
    5 Use the - button to contract the void. The void will be contracted by x amount without changing the size of the shape.
    6 Right-click and choose Done from the pop-up menu.
    Try these steps as it would help to contract the voids inside shape by an 'x' amount without changing the size of the shape.
  • masamasa
    0 masamasa over 2 years ago in reply to techiecs
    regards
    masa
