  3. Updating shape
  • State Suggested Answer
  • Answers 2
  • Views 6503
Updating shape
NathanMPS
NathanMPS over 2 years ago
Hello
Is it possible to update the segments of a shape so that they match the current shape?
For example, in the photo below, the segment in green would match the shape in red (doing this arc segment automatically) :
  • techiecs
    techiecs over 2 years ago +1 suggested
    You can try the below steps using Shape>Edit Boundary command to change the corners to arcs- 1 Select Shape>Edit Boundary. 2 Click LMB on the shape to edit. 3 Under the Options tab, change the Segment…
  • steve
    0 steve over 2 years ago
    Try the Edit - ZCopy command. Works like an offset command. look at the Options pane and set the layers you want to copy to, set the contract / expand amount to offset then select the shape you want to copy from.
  • techiecs
    0 techiecs over 2 years ago
    3 Under the Options tab, change the Segment Type to Arc.
    4 Click the LMB on the start point for the arc along the boundary edge (an arc point will be attached to the cursor).
    5 Select and stretch the arc to finish line of the other segment.
    If required, use RMB and select Flip Dynamics to change the arc direction.
    6 Click RMB and select Done to finish the current operation.
    Give it a try and let me know how it goes for you after performing the steps.
