  3. void on shape conversion
  • State Verified Answer
  • Views 7221
masamasa
masamasa over 2 years ago
hello
i have a shape with a void.
is there a way to convert a void on a shape into a shape on route keepout?
the converted shape on route keepout should be the same shape of the void.
regards
masa
  • SaiPavanl
    SaiPavanl over 2 years ago +3 verified
    Allegro PCB Editor will not allow you to copy one void from one shape to another shape. Workaround: Create a route keepout (RKO) for the void and copy the RKO to other areas/shapes. To do this: …
  • masamasa
    masamasa over 2 years ago in reply to SaiPavanl +1
    thank u for ur response. yes, this works. how can i do the other way around? is there a way to convert a shape on a route keepout into a void in a shape? regards masa
  • SaiPavanl
    +1 SaiPavanl over 2 years ago
    Workaround:
    To do this:
    1. Select Shape > Decompose Shape and select the shape with the void that you would like to copy. This will create a set of lines on the class/subclass that includes both the shape outline and the void outline
    2. Turn off all layers except the Drawing Format/Construction class/subclass for easier viewing.
    3. Select Shape > Compose Shape. Under the Options tab change the Active class/subclass to Route Keepout/Subclass Layer X where you want the keepout. Select all lines of the void outline that you want to copy, either one at a time or by drawing a window around them.
    4. This will create a Route Keepout shape that will void etch on the specified class/subclass and can be copied to other shapes and subclasses using Edit > Change.
    Another option is to use Edit > Z-Copy to convert the existing Static Shape to Dynamic while preserving the Net Name/Voids.
    The only issue here is it will not allow it to be created on the same layer. Hence after Z-Copy is complete you need to use Edit > Change to move it back.
    If Route Keepouts are needed. Define another static shape on top of the existing one and use Shape > Void Element to void the new shape to the old. This will create individual shapes in the void opening which can be copied to the Route Keepout Subclass using Z-Copy.
    • Vote Up +3 Vote Down
  • masamasa
    0 masamasa over 2 years ago in reply to SaiPavanl
    yes, this works.
    regards
    masa
