  3. shape to void conversion
  • State Suggested Answer
  • Answers 1
  • Subscribers 166
  • Views 7721
masamasa
masamasa over 2 years ago
hello
is there a way to convert a shape on a route keepout into a void of some other shape?
regards
masa
  • Hoangkhoipcb
    Hoangkhoipcb over 2 years ago in reply to somit +1 suggested
    yes. but we use SKILL is resolve quite this problem. ( axlDBCreateVoid (openShape, poly))
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago
    If you copy the route keepout shape it should automatically void the shape you place it into, or am I not understanding your issue correctly?
  • masamasa
    0 masamasa over 2 years ago in reply to DavidJHutchins
    thank u for ur reply.
    i am sorry that i did not make it clear.
    usually ur method works.
    however i would like to make a void without using a route keepout as many pads inside the void.
    regards
    masa
  • steve
    0 steve over 2 years ago in reply to masamasa
    Just as a FYI you can add exceptions for Route Keepout shapes if that helps in this scenario. This can either be a property on the shape (like Pins_Allowed) or can be a specific set of nets (so pins / vias for a net). For this look at Constraint Manager - Properties - Net - Route/Via Keepout Exceptions. This may mean you can add a Route Keepout rather than a void.
  • masamasa
    0 masamasa over 2 years ago in reply to steve
    this feature on the property is the one u told me years ago and i use it frequently.
    i have a design with a void in which about a thousand of pads created by shapes exist.
    i guess i have create the void manually.
    regards
    masa
  • somit
    0 somit over 2 years ago
    No i don't think it is easy.
