  3. via to via spacing on the same layer
  • State Verified Answer
  • Replies 7
  • Views 9392
masamasa
masamasa over 2 years ago
hello
is there a way to check the via-to-via spacing on the same layer.
let us say we have 3 different padstacks, a, b, and c.
the constraint manager can allow the minimum sapcing setup between padstacks a and b but it seems there is no spacing setup between padstacks a and c
if the minimum spacing between padstacks a and b on different layers is set up, i can not catch the minimum spacing between padstacks a and c on the same layer.
all three vias have different nets.
regards
masa
  • techiecs
    techiecs over 2 years ago +1
    -SPB 17.4 Hotfix 28 (QIR4) onward, you can set the same net checks for via pads and holes(Same net Hole to Hole and Via to Via checks) by using the Allegro PCB venture license. -To set these checks, first…
  • Hoangkhoipcb
    Hoangkhoipcb over 2 years ago in reply to masamasa +1 verified
    i understand your issue. this is my method Find minimun airgap via to via at the each layers( using cmd Min airgap). Go to constraint manager adjust value as return before step. Checking DRC error…
  • masamasa
    0 masamasa over 2 years ago in reply to Hoangkhoipcb
    wow, thank u for ur response.
    yes this works.
    i did not know the setup for dielectric layers.
    regards
    masa
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago in reply to masamasa
    you don't care dielectric layers. There is a example. Please change suitable your design.
