  3. via to via spacing on the same layer
  • State Verified Answer
  • Replies 7
  • Views 9391
masamasa
masamasa over 2 years ago
hello
is there a way to check the via-to-via spacing on the same layer.
let us say we have 3 different padstacks, a, b, and c.
the constraint manager can allow the minimum sapcing setup between padstacks a and b but it seems there is no spacing setup between padstacks a and c
if the minimum spacing between padstacks a and b on different layers is set up, i can not catch the minimum spacing between padstacks a and c on the same layer.
all three vias have different nets.
regards
masa
  • techiecs
    techiecs over 2 years ago +1
    -SPB 17.4 Hotfix 28 (QIR4) onward, you can set the same net checks for via pads and holes(Same net Hole to Hole and Via to Via checks) by using the Allegro PCB venture license. -To set these checks, first…
  • Hoangkhoipcb
    Hoangkhoipcb over 2 years ago in reply to masamasa +1 verified
    i understand your issue. this is my method Find minimun airgap via to via at the each layers( using cmd Min airgap). Go to constraint manager adjust value as return before step. Checking DRC error…
  • techiecs
    0 techiecs over 2 years ago
    -To set these checks, first, create the DFF CSet under Manufacturing > Design for Fabrication > DFF constraint set > Copper spacing and expand the 'Same net checks'.
    -After creating DFF copper spacing CSet and setting the CSet usage as Etch, assign this CSet to the referenced DFF CSet under Design for Fabrication > Design > Copper Spacing.
    -In analysis modes, enable the same net checks under Design For Fabrication > Copper Spacing.
    Similarly, under Design for Fabrication>DFF constraint set>Copper Spacing, there are checks for 'Vias' here.
    You might give it a try to see if it helps in your scenario to check via to via spacing.
  • masamasa
    0 masamasa over 2 years ago
    thank u for ur response.
    the vias can be either with same nets and/or different nets.
    but most likely i would like to get a spacIng setup for different nets
    regards
    masa
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago in reply to masamasa
    hi masamasa! Do you have any methods to handle that problem?
  • masamasa
    0 masamasa over 2 years ago in reply to Hoangkhoipcb
    no i do not.
    i do not have any method or solution to this problem so i posted this question.
    i hope cadence can give us a solution to this problem.
    regards
    masa
  • Hoangkhoipcb
    +1 Hoangkhoipcb over 2 years ago in reply to masamasa
    • Find minimun airgap via to via at the each layers( using cmd Min airgap).
    • Go to constraint manager adjust value as return before step.
    • Checking DRC error.
    I hope help you resolve  issue.
    Hoangkhoi
