  3. creating a netlist
  • State Verified Answer
  • Replies 14
  • Answers 1
  • Views 15864
creating a netlist
masamasa
masamasa over 2 years ago
hello
is there an easy way to create a netlist in the format that can be imported in the board design?
regards
masa
  • DavidJHutchins
    DavidJHutchins over 2 years ago in reply to masamasa +1 verified
    If you run the code & cancel out of the file browser you will get the message "No valid file selected" If your input file has any lines where the Refdes, Pin_number or Net_name are empty, that line will…
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago
    In Allegro the File>Export>Netlist w/Properties... will generate ASCII netlist.txt, which is in the Allegro native 'Telesis' format
    You can edit the netlist file & import it back into Allegro using the File>Import>Logic/Netlist... 'Other' tab
    The netlist format is documented in 'Allegro® User Guide: Transferring Logic Design Data' chapter 'Creating, Comparing, and Updating Databases'
  • masamasa
    0 masamasa over 2 years ago in reply to DavidJHutchins
    thank u for ur response, david.
    i do understand the netlist format but it takes a half day to create a netlist from the netlist our customers send us.
    our customers usually send us a netlist like the one we get on a symbol pin report as shown below.
    from this symbol pin report, is there a skill or some easy method to create a netlist in the format that can be imported in the board design?
    regards
    masa
  • Tyler
    0 Tyler over 2 years ago in reply to masamasa
    Are you working on a board or a package? The screenshot looks like a typical CSV netlist that you can import into a package design through APD+ and the file - import - netlist text in wizard. The format is similar to a CSV file for a die, package, or other component.
    Since many package designs are still done without a front end schematic for the logic, this is a popular format. For a board design, a schematic is almost always available, which is why the format isn’t utilized in that flow.
    if you’re bringing the netlist into a board design, the schematic tool you’re using in the front end may support reading this format. Where is it coming from out of your customer? Do they have other netlist formats available?
  • masamasa
    0 masamasa over 2 years ago in reply to Tyler
    thank u for ur response, tyler.
    i am working on apd and do not use schematic
    please let me try the netlist in wizard
    it looks like the netlist in wizard takes txt files.
    regards
    masa
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago in reply to masamasa
     masamasa
    it seem you same my work , do not use schematic and package only.
    Let's talk together if you're having trouble
    HoangKhoi.
