  3. creating a netlist
  • State Verified Answer
  • Replies 14
  • Answers 1
  • Views 15872
creating a netlist
masamasa
masamasa over 2 years ago
hello
is there an easy way to create a netlist in the format that can be imported in the board design?
regards
masa
  • DavidJHutchins
    DavidJHutchins over 2 years ago in reply to masamasa +1 verified
    If you run the code & cancel out of the file browser you will get the message "No valid file selected" If your input file has any lines where the Refdes, Pin_number or Net_name are empty, that line will…
  • avant
    0 avant over 2 years ago in reply to masamasa
    Try opening the customer netlist file in Excel.
    Then, manipulate the cells and save the spread sheet as a text file.
    The final (text) format would look something like this:
    VSS ; BGA.A3
    VSS ; BGA.A4
    I use Excel to convert a customer's placement file from English to Metric.
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago in reply to avant
    The symbol pin report you showed appears to be created from within Allegro/APD, which is now HTML based so it's almost impossible to parse ( Thanks Cadance... )
    Import the file into Excel as a comma separated file & then save as a csv file ( which is similar to the report -v spn file format )
    Below is an example of running the skill code I wrote this morning to read the csv file to assign the nets:
    skill load "csv_net_import.ils"
    variable csv_net_import redefined
    Autosave time limits are: 5 to 300 minutes
    t
    skill csv_net_import
    Loaded existing device file 'C:\Temp\devices.dml'
    Finished loading SigNoise device libraries
    640 lines read, 563 net assignments made
    t
    The skill code is shown below:
    procedure(csv_net_import()
    let((FileName inport DataLine DataList RefDes PinTxt NetTxt Cmp Pin Net Status LineCnt Assigned)
    (LineCnt = 0)
    (Assigned = 0)
    (FileName = axlDMFileBrowse( nil nil ?optFilters " files(*.csv)|*.csv|"))
    if(( stringp(FileName) && (isFile(FileName) == t)) then
    (inport = infile(FileName))
    (axlClearSelSet)
    while(gets(DataLine inport)
    (LineCnt++)
    (DataList=parseString(DataLine ",\n\r"))
    (RefDes = car(DataList))
    (PinTxt = cadr(DataList))
    ;(Net = cadr(Reverse(DataList)))
    (NetTxt = nth(7 DataList))
    when(RefDes && PinTxt && NetTxt
    (Cmp = car(axlSelectByName("COMPONENT" RefDes)))
    when(Cmp
    (Pin = car(axlSelectByName("PIN" (strcat RefDes "." PinTxt))))
    when(Pin
    (Net = axlDBCreateNet(NetTxt))
    (Status = axlDBAssignNet(Pin Net nil t))
    when(Status
    (Assigned++)
    (axlClearSelSet)
    close(inport)
    drain()
    axlMsgPut("%d lines read, %d net assignments made" LineCnt Assigned)
    else
    axlMsgPut("No valid file selected")
  • masamasa
    0 masamasa over 2 years ago in reply to DavidJHutchins
    thank u for ur skill code, david.
    i have tried this and got this message.  is it automatically assign the net to the pin without importing the netlist?
    the command line says 34387 lines read, 34386 net assignments made.
    the total pin count is 34387 on the symbols and on the csv files as well.
    after excuting the skill code, the symbol pin report has 34387 pins.
    i wonder why 1 pin is missing for the net assignment.
    i reduced the net count to 4 and excuted the code and still one net less than the line count in the result on the command line.
    it took me about an hour to excute this code for the 34387 pins..  if this works, it would be a great time saver compared with spending a half day to create a netlist from scratch.
    regards
    masa
  • DavidJHutchins
    +1 DavidJHutchins over 2 years ago in reply to masamasa
    If your input file has any lines where the Refdes, Pin_number or Net_name are empty, that line will be reported as an error and skipped
    I added some error reporting to the skill code, latest version included below:
    let((FileName inport DataLine DataList RefDes PinTxt NetTxt Cmp Pin Net Status LineCnt Assigned ErrorCnt)
    (LineCnt = 0)
    (ErrorCnt = 0)
    (Assigned = 0)
    (axlClearSelSet)
    (LineCnt++)
    ;axlMsgPut(" RefDes %s PinTxt %s NetTxt %s" RefDes PinTxt NetTxt)
    ;when(plusp(strlen(RefDes)) && plusp(strlen(PinTxt)) && plusp(strlen(NetTxt))
    if( RefDes && PinTxt && NetTxt then
    when(Cmp
    when(Pin
    if(Status then
    (Assigned++)
    else
    axlMsgPut("Error: line # %d generated no connectivity: %s" LineCnt DataLine)
    (ErrorCnt++)
    else
    axlMsgPut("Error: line # %d has formatting issues: %s" LineCnt DataLine)
    (ErrorCnt++)
    (axlClearSelSet)
    close(inport)
    drain()
    axlMsgPut("%d lines read, %d net assignments made, %d errors found" LineCnt Assigned ErrorCnt)
    else
  • masamasa
    thank u david for creating the skill code.
    i am sorry for delaying my response as we had a week long holiday in japan.
     i was able to import all 4 nets by using the skill code
    the first row was missing so i added the first row and it works now.
    regards
    masa
