  3. creating a netlist
  • State Verified Answer
  • Replies 14
  • Answers 1
  • Views 15880
creating a netlist
masamasa
masamasa over 2 years ago
hello
is there an easy way to create a netlist in the format that can be imported in the board design?
regards
masa
  • DavidJHutchins
    DavidJHutchins over 2 years ago in reply to masamasa +1 verified
    If you run the code & cancel out of the file browser you will get the message "No valid file selected" If your input file has any lines where the Refdes, Pin_number or Net_name are empty, that line will…
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago in reply to masamasa
    I duplicated your design data  to test the skill code:
    C:\Temp>
    C:\Temp>cat test.csv
    BGA,A3,BGA,BGA,BGA_PAD,27000,-29000,VSS
    BGA,A4,BGA,BGA,BGA_PAD,26000,-29000,VSS
    DIE,30469,DIE_NEW,DIE_NEW,FC_PAD,23315,-14115,NC
    DIE,30470,DIE_NEW,DIE_NEW,FC_PAD,23315,-14315,NC
    C:\Temp>wc test.csv
      4   4 182 test.csv
    C:\Temp>
    I did not have any issues loading the netlist...
    C:\Temp>tail allegro.jrl
    \t (00:20:45) Autosave successful
    \w (00:20:45) Autosave time limits are: 5 to 300 minutes
    \i (00:20:59) skill csv_net_import
    \i (00:21:03) fillin "test.csv"
    \t (00:21:03) 4 lines read, 4 net assignments made, 0 errors found
       (00:21:03) t
    \i (00:22:42) save
    \i (00:22:42) generaledit
    \i (00:22:47) exit
    \t (00:22:47)     Journal end - Mon Aug 19 09:27:29 2024
    C:\Temp>
    Are you using the latest skill code I posted 10 days ago?
  • masamasa
    0 masamasa over 2 years ago in reply to DavidJHutchins
    thank u for ur response, david.  i really appreviate it.
    yes i used ur latest skill code posted 10 days ago.
    with the first tow, i get this.
    this works fine as all 4 nets r imported.
    but without the first row, i get this.
    one last net is not imported.
    this is weird.  maybe it is because i use apd so the format may be slightly different.
    regards
    masa
  • DavidJHutchins
    I do not believe you are using the latest skill code, since the summary line does not include the error count as shown from my test:
    Also, do the files for 'DIE' symbol have pin number 29332 ?
  • masamasa
    thank u david for ur response.
    i double checked the skill code and confirmed that I use the latest one which does not show "0 errors found" on my command line, weird.
    i changed the netlist slightly (changing the pin #30470 to pin #29332) to see how the skill code assigns the nets to the pins.
    i noticed before importing the csv file, i need to clear all the nets already assigned to the pins by using deassign net.
    otherwise, if pin #30470 is assigned to NC prior to the csv import and the csv file does not contain pin #30470, then pin #30470 would still stay with NC after importing the csv file.
    regards
    masa
