  3. How to edit the pin pairs within the "Etch Length by Pin...
  • State Verified Answer
  • Answers 1
  • Views 3900
How to edit the pin pairs within the "Etch Length by Pin Pair" report?
DN202408143132
DN202408143132 over 2 years ago
Does anyone know how to edit the pin pairs within the "Etch Length by Pin Pair" report? Is there a custom report that I could generate to change the pin pairs to ones I want?
Thanks.
  • John T
    John T over 2 years ago in reply to DN202408143132 +2 verified
    There is a seperate thread for SKILL users to discuss such topics. Perhaps users on this forum will help you. Allegro X Scripting - Skill You will find a recent introduction post there also: Introduction…
  • John T
    0 John T over 2 years ago
    I have seen this query in the past and currently there is no direct tool solution for this. Advanced users are utilising SKILL code solutions to create such a customised report.
  • DN202408143132
    0 DN202408143132 over 2 years ago in reply to John T
    Would you happen to know if the preexisting reports run off of SKILL code too? If so where could you find it?
  • John T
    0 John T over 2 years ago in reply to DN202408143132
    The reports run from extracta text files. Each report has its own extracta file that tells the database what information you want to extract.
    You can create or edit your own reports in the Reports Tools Window. Alternatively use the preexisting extracta files (Quick Reports). Most of these are stored in your $textpath set within your user preferences. For 23.1 this folder would typically be found at C:\Cadence\OrCADX_23.1\share\pcb\text\views.
  • DN202408143132
    Thanks for the reply. I was looking through that path and was I wasn't able to find the report for Etch Length by Pin Pair. I am reading more about SKILL currently and trying to get that to work. Do you have any references to other users getting the etch length with custom pin pairs?
  • John T
    +1 John T over 2 years ago in reply to DN202408143132
    You will find a recent introduction post there also:  Introduction to SKILL
    As a hint for your requirement, I would point you in the direction of the function axlDBGetLength(). You may want to discuss this function with users there.
    • Vote Up +2 Vote Down
