  3. PROBLEMS WITH ALLEGRA AND FOOTPRINTS ORCAD X
  • State Verified Answer
  • Views 6970
LAMCO
LAMCO over 2 years ago
I am creando a design in ORCAD X, I active the Layout in ORCAD X PCB but I try visualize the model 3D en Allegro, the components are missing in the plate, instead of them, gray cubes appear. I can read the next messages:
Symbol representation is set to: Step Model if available, else the Place_Bound Shape. Symbols without an assigned STEP Model are displayed using the Place_Bound Shape.
Creating 3D SILKSCREEN_BOTTOM with default thickness 0.5 mils because SILKSCREEN_BOTTOM is not defined in the cross section.
Creating 3D PASTEMASK_BOTTOM with default thickness 0.5 mils because PASTEMASK_BOTTOM is not defined in the cross section.
Creating 3D SOLDERMASK_BOTTOM with default thickness 0.5 mils because SOLDERMASK_BOTTOM is not defined in the cross section.
Creating 3D SOLDERMASK_TOP with default thickness 0.5 mils because SOLDERMASK_TOP is not defined in the cross section.
Creating 3D PASTEMASK_TOP with default thickness 0.5 mils because PASTEMASK_TOP is not defined in the cross section.
Creating 3D SILKSCREEN_TOP with default thickness 0.5 mils because SILKSCREEN_TOP is not defined in the cross section.
Thank You for you help.
  • John T
    John T over 2 years ago +2 verified
    Hi Lamco, this looks like you do not have any step model files for this design. The step models are typically stored in a seperate folder. Can you locate these? (files with extension ".stp" or ".step…
  • John T
    John T over 2 years ago in reply to LAMCO +1
    Hi Lamco, yes I would agree with you - the capacitor model is either missing from the folder OR it has a slight difference in the filename. You could check for this in your folder also and could change…
  • John T
    +1 John T over 2 years ago
    (files with extension ".stp" or ".step").
    For your information, full board level 3D step mapping functionality is coming soon in OrCAD X 24.1. For this, you will need to ensure that you have step files available in order to map a 3D model to each component.
    • Vote Up +2 Vote Down
  • LAMCO
    0 LAMCO over 2 years ago in reply to John T
    Hi John,
    Thank you for you request and help, understand the indcations, maybe, I try search the folder with extension, but its not there, you know any path, route or possible location of this folder.
    Greetings.
  • LAMCO
    Ok, I find some folder with files Steps and in Orcad X, I use the option Setup --->Step makking according to this video https://resources.pcb.cadence.com/orcad-x-pcb-design-videos/step-support-mapping-3d-models-3 maybe the Step Model file capacitor´s is not in the folder, I need download the file right?
  • John T
    0 John T over 2 years ago in reply to LAMCO
    Hi Lamco, yes I would agree with you - the capacitor model is either missing from the folder OR it has a slight difference in the filename. You could check for this in your folder also and could change the filename or remap an alternate model.
    The resource info you found is actually for our oldest 3D tool which is still available and works, but it is has already been succeeded by a superior interface. A separate icon is available to launch our current "3D Canvas" tool.  Please look for this icon:
    I will provide resource info for this here:
    https://community.cadence.com/cadence_blogs_8/b/pcb/posts/mapping-cad-models-to-footprints
    In fact, there is a newer 3D engine in development for our newest, alternative PCB Editor (OrCAD X Presto) which was launched just last year. But for now you can use the 3D Canvas tool in our classic OrCad PCB Editor which has an excellent interface for mapping new components.
