  3. Display Your Know How: Footprints
  • Replies 18
  • Subscribers 167
  • Views 16247
PCBTech
PCBTech over 2 years ago
Which footprint option is best, A or B?
Let’s say your PI specialist advises that this part requires maximum power transfer according to the component rating… Which library footprint do you choose?
Simply answer by letter or include any reason to support your answer. Alternatives and opinions are welcome!
  • avant
    avant over 2 years ago +1
    Paste pattern is related to reflow. We would use the manufacturer's data sheet recommendation and have our assembly shop review. The pad can be tied into a copper shape for heat dissipation if required…
  • Byron365
    Byron365 over 2 years ago +1
    Every Contract Manufacturer (CM) I have ever worked with wants option B. I believe this was originally born out of the fact that squeegee blades on solder paste screening equipment wasn't always a steel…
  • DE202408202727
    DE202408202727 over 2 years ago +1
    There is no simple answer to this question. B is going to be a better option for most requirements but the split shown will only give about 30% paste coverage. Using fewer larger tiles would increase the…
  • PCBTech
    PCBTech over 2 years ago in reply to excellon1
    Yes also good point excellon1. Does your stencil supplier have a recommended minimum arc radius for stencil openings? Our experience is that this radius would typically be very small? (circa <= 50um)
    Perhaps there are also other reasons for rounding stencil corners..?
  • DE202408202727
    DE202408202727 over 2 years ago in reply to PCBTech
    Yes, that's a good split.
    Rounding the corners isn't really necessary on relatively large apertures.
    In reality, rounding corners these days is only necessary to increase an area ratio on small pads where the ratio is less than about 0.7. Square corners have much less effect on paste release than the smoothness of the stencil walls. This is often enhanced with use of nano coating.
  • Wild
    Wild over 2 years ago
    B is better (Per IPC7093A) but the corners should have a radius of at least the diameter of the solder power.  This will help in the paste release.  Also the Pas to pad area needs to be calculated - target is between 50% and 80% to avoid voids.  There are no thermal via;s shown, the paste areas need to be such that these vias area avoided best as possible.
  • John T
    John T over 2 years ago in reply to Wild
    Thanks Wild - I found your points very interesting! Upon rereading, can you clarify your meaning of solder "power". Are you referring to solder ball size here? Just for my own education - I would be interested to know thanks!
  • Wild
    Wild over 2 years ago in reply to John T
    Here is a link to The company AIM website that has details on Solder Powder:
    aim alloys
    BTW - the SAC305, SAC405, SAC505 - the first digit is the Power Size.  So SAC305 is the type 3 with diameters ranging from 25-45um
