  3. Display Your Know How: Footprints
  • Replies 18
  • Subscribers 167
  • Views 16258
PCBTech
PCBTech over 2 years ago
Which footprint option is best, A or B?
Let’s say your PI specialist advises that this part requires maximum power transfer according to the component rating… Which library footprint do you choose?
Simply answer by letter or include any reason to support your answer. Alternatives and opinions are welcome!
  • avant
    avant over 2 years ago +1
    Paste pattern is related to reflow. We would use the manufacturer's data sheet recommendation and have our assembly shop review. The pad can be tied into a copper shape for heat dissipation if required…
  • Byron365
    Byron365 over 2 years ago +1
    Every Contract Manufacturer (CM) I have ever worked with wants option B. I believe this was originally born out of the fact that squeegee blades on solder paste screening equipment wasn't always a steel…
  • DE202408202727
    DE202408202727 over 2 years ago +1
    There is no simple answer to this question. B is going to be a better option for most requirements but the split shown will only give about 30% paste coverage. Using fewer larger tiles would increase the…
  • Wild
    Wild over 2 years ago in reply to John T
    I had tried to post a reply but Cadence flagged it as spam.
    Go to the AIM site (www.aimalloys.com/products/solder-powder) and there is a description of solder powder.
    The photo shows the powder size, you can see that SAC305 has a powder ball size of 25 to 45um, 4 and 5 also shown.
  • Wild
    Second post was also flagged as spam.
    Just search on Solder Powder, pictures and websites such as AIM alloys with give you a good description.
    Note SAC305 uses type 3 powder ball size which is 25 to 45um, type 4 is 20 to 38 um and type 5 is 15 to 25 um.
  • John T
    John T over 2 years ago in reply to Wild
    Yes any external links are automatically flagged for site safety reasons. These are approved now after review.
  • John T
    Thanks for clarifying. I find this interesting - I had not heard of this rule before. Therefore the corner of the stencil should allow safe passage of the solder by matching maximum diameter of the solder ball ( or max radius I guess.) This makes total sense!
    Had you heard of the 5-ball rule for stencil aperture widths?
  • Wild
    Are you referring to the aspect ratio?  These are spelled out in the IPC7093 B standard.
    Attaching a document I created but not released for BTC footprints.BTC footprint guidelines.pdf
