  3. Display Your Know How: Footprints
  • Replies 18
  • Subscribers 167
  • Views 16260
PCBTech
PCBTech over 2 years ago
Which footprint option is best, A or B?
Let’s say your PI specialist advises that this part requires maximum power transfer according to the component rating… Which library footprint do you choose?
Simply answer by letter or include any reason to support your answer. Alternatives and opinions are welcome!
  • avant
    avant over 2 years ago +1
    Paste pattern is related to reflow. We would use the manufacturer's data sheet recommendation and have our assembly shop review. The pad can be tied into a copper shape for heat dissipation if required…
  • Byron365
    Byron365 over 2 years ago +1
    Every Contract Manufacturer (CM) I have ever worked with wants option B. I believe this was originally born out of the fact that squeegee blades on solder paste screening equipment wasn't always a steel…
  • DE202408202727
    DE202408202727 over 2 years ago +1
    There is no simple answer to this question. B is going to be a better option for most requirements but the split shown will only give about 30% paste coverage. Using fewer larger tiles would increase the…
  • jc teyssier
    jc teyssier over 2 years ago
    Depend on your assembly house: each one use different rule.
    We use "A" since assembly house may vary. Each one adapt solder paste film to their own process.
    Some use "A", some use "B,  some use "B" BUT not square but round, some....
  • John T
    John T over 2 years ago in reply to Wild
    Yes this is what I meant. These are good guidelines - thank you!
  • John T
    John T over 2 years ago in reply to jc teyssier
    Thanks JC - I imagine this depends if you use thermal vias within the pad also.
    I am interested to know if anyone has experience with outgassing or the effects the layout has on solder voiding.
