  3. How to use the place by room in the Quickplace tab
  • State Verified Answer
  • Views 5521
RohitRohan
RohitRohan over 2 years ago
Hai Community,
In the PCB Editor, Place >> Quickplace, there is option for Place by room.
How to use the Place by room in the Quickplace tab.
Rohit Rohan.
  • steve
    steve over 2 years ago +1 verified
    Basic principle is you add a property to the parts in the schematic, property name ROOM, value the name of the ROOM so IC, Channel, Memory etc. Once you generate the PCB you can draw a room outline (look…
  • steve
    +1 steve over 2 years ago
    Basic principle is you add a property to the parts in the schematic, property name ROOM, value the name of the ROOM so IC, Channel, Memory etc. Once you generate the PCB you can draw a room outline (look at Setup - Outlines - Room Outline or Outline - Room for OrCAD licenses). You can draw these based on the Room names you defined in the schematic. Once the rooms are drawn you can then use the Quickplace command.
