  3. update layout creates a Rectangle "Board Geometry/Top_Room...
  • State Verified Answer
  • Replies 24
  • Answers 2
  • Subscribers 172
  • Views 12298
update layout creates a Rectangle "Board Geometry/Top_Room" that cannot be removed
JC202409239850
JC202409239850 over 2 years ago
This is my first time designing my PCB with Cadence tools. I placed several parts on the PCB design, then I went back to the schematic to make some changes to the connectors. When I came back to the PCB editor and selected "update layout", the editor added all the parts that were not yet placed in a rectangle region named "1". The rectangle cannot be deleted with Edit->Delete command. Can anyone give some hints on how to remove it?
  • John T
    John T over 1 year ago in reply to Zhifeng Jin +3 verified
    Hi Zhifeng thanks for sending this. I have managed to delete this room. It turns out to have been assigned a "fixed private" state. We will investigate this further in the tool. For now the fix is to…
  • FaPb
    FaPb over 1 year ago in reply to EStedt +2
    Run Tools > Database check. Then delete it as a shape. That worked in my case.
  • John T
    John T over 2 years ago +1 suggested
    Hi JC, to remove rooms please use menu: Setup > Outline > Room Outline. To setup the board outline you should also invoke the Design Outline setup tool from the setup menu before placing any compo…
  • John T
    0 John T over 2 years ago in reply to JC202409239850
    Ok thanks JC - I will try that. If I cannot recreate I may contact you by mail to exchange a copy of your design. Let me see if I can recreate first, then I can find out why this is not deleting.
  • EStedt
    0 EStedt over 1 year ago in reply to John T
    Has this fault been resolved? Facing the same issue...
  • FaPb
    0 FaPb over 1 year ago in reply to EStedt
    • Vote Up +2 Vote Down
  • gvellet
    0 gvellet over 1 year ago in reply to JC202409239850
    Same problem with Orcad 24.1 S003.
    The bug occurred when in capture I sync the PCB with the option "Place Always" enabled.
    Impossible to delete because an unknown parent is FIXED.
    Only solution is to delete board and start with version prior to PCB sync" And this time redo sync with the capture option "Place Never"
  • Ulf K
    0 Ulf K over 1 year ago in reply to gvellet
    Hotfix 005 was released a short while ago.
    Anyone tried the (failing) procedure above with this HF installed?
