  3. update layout creates a Rectangle "Board Geometry/Top_Room...
  • State Verified Answer
  • Replies 24
  • Answers 2
  • Subscribers 172
  • Views 12308
update layout creates a Rectangle "Board Geometry/Top_Room" that cannot be removed
JC202409239850
JC202409239850 over 2 years ago
This is my first time designing my PCB with Cadence tools. I placed several parts on the PCB design, then I went back to the schematic to make some changes to the connectors. When I came back to the PCB editor and selected "update layout", the editor added all the parts that were not yet placed in a rectangle region named "1". The rectangle cannot be deleted with Edit->Delete command. Can anyone give some hints on how to remove it?
  • John T
    John T over 1 year ago in reply to Zhifeng Jin +3 verified
    Hi Zhifeng thanks for sending this. I have managed to delete this room. It turns out to have been assigned a "fixed private" state. We will investigate this further in the tool. For now the fix is to…
  • FaPb
    FaPb over 1 year ago in reply to EStedt +2
    Run Tools > Database check. Then delete it as a shape. That worked in my case.
  • John T
    John T over 2 years ago +1 suggested
    Hi JC, to remove rooms please use menu: Setup > Outline > Room Outline. To setup the board outline you should also invoke the Design Outline setup tool from the setup menu before placing any compo…
  • Timor77
    0 Timor77 over 1 year ago in reply to Ulf K
    This still happens with 005.
    Can delete the room also not through the Room Outline window. It shows it has fixed propery.
    Database check also didn't,
  • Zhifeng Jin
    0 Zhifeng Jin over 1 year ago in reply to Timor77
    I have encountered the same situation as you. Have you resolved it now?
  • Timor77
    0 Timor77 over 1 year ago in reply to Zhifeng Jin
    No. I didn't find a solution for that.
  • John T
    0 John T over 1 year ago in reply to Timor77
    Hi Timor, do you want to send me a copy of your pcb database for this so we can troubleshoot. I don't have a copy of this from the original query as requested. I will send you a PM for this.
  • John T
    0 John T over 1 year ago in reply to Zhifeng Jin
    Hi Zhifeng Jin, I still do not have a database to check this issue. I hope you can send so we can finally get to the bottom of this.
    I will send you a friendship request on this community site so that we can exchange by mail.
