  3. About Allegro max stacked via count in DFF rule
  • Views 5665
zpofrp
zpofrp over 2 years ago
There are many bbvia or uvia in my design, Via_L1_L4,Via_L2_L3,Via_L5_L6,Via_L1_L2, and so on. The Via_L5_L6 is PTH via. orther via is laser via.
I want to check the max laser via count and laser via count in PTH via.
I find a fuction in manufacturing> design for fabrication. But it's not what I wanted.
For example i set the max stacked via count =2, But there is no DRC when Via L1 to L6(Via_L1_L5+ Via_L5_L6).
Only bbvia count nore than 2, Via_L1_L2+ Via_L2_L3+Via_L3_L4.
  • John T
    John T over 2 years ago
    Hi zpofrp, so you are stating that the uvia is not counted, only the bbvias - is that correct? You mention that "Via_L5_L6" is a PTH so I am little confused by this...
    Can you tell us if the uvias are defined in the bbvia definitions? It is possible to mark these as uvia in this interface:
  • zpofrp
    zpofrp over 2 years ago in reply to John T
    There are laser via and mechanical via in the package deign. The PTH is Plating Through Hole, usually it  through the Core layer.
    I don't defined the uvias in the bb via definitions. I have never used Uvia. I will relize Uvia.
    I want to show the DRC for max via count more than 3. for example L1 to L4, L2 to L5,L3 to L6, and so on.
    I mean the max via count is the number that passes through the dielectric.
    But the DFF is set based on bbvia or Uvia count.
  • zpofrp
    II know the UVIA is microvia. so i can set the PTH is BBVIA, the laser via is MicroVia. But i dont think it is going to solve my problem.
    i want to show DRC for more than a number than through the dielectric.
