  3. converting pins to vias
  • State Verified Answer
  • Views 5807
masamasa
masamasa over 2 years ago
hello
i have completed a design with a symbol that has pins.
our customer is now asking me to change the pins that are attached to the symbol to vias which are independent from the symbol.
i have 30k pins on the symbol so i would like to find some easy way to do this.
regards
masa
  • excellon1
    0 excellon1 over 2 years ago
    Hi Masa,
    The actual symbol has to have pins otherwise there is no net info. I think the best you can do is to change the physical padstack associated with each pin so
    it is of similar size to a via.
    Best Regards.
  • masamasa
    +1 masamasa over 2 years ago in reply to excellon1
    thank u for ur response.
    removing pins from a symbol is no problem.
    the problem is to place vias at the same locations wherre the pins were.
     i found a way to do this.
    1. export a pin layer as a dxf file
    2. import it back to the design
    3. convert lins to shapes and shapes to vias.
    regards
    masa
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago in reply to masamasa
    Hi Masa!
    Can you refer this code
    I hope this is your solution
    HoangKhoi
  • masamasa
    0 masamasa over 2 years ago in reply to Hoangkhoipcb
    thank you for ur reply, hoangkhoi
    i have tried ur skill but get this error.
    regards
    masa
  • Hoangkhoipcb
    Hi Masa!
    It's working on Allegro 17.4. I think you're opening the APD license,
    or you should comment out lines 5 and 6, then try again
    HoangKhoi
