  3. merging two padstacks into one
  • State Verified Answer
  • Answers 1
  • Views 5966
masamasa
masamasa over 2 years ago
hello
a L1-L2 padstack and a L2-L3 padstack are located at the same location as a stacked via.
is there a way to merge a L1-L2 padstack and a L2-L3 padstack into one single L1-L3 padstack?
regards
masa
  • DavidJHutchins
    DavidJHutchins over 2 years ago in reply to masamasa +1 verified
    The attached zip file contains a skill file that implements the custom command "merge_stackedvias" The rules file "MergeStackedVias.txt" is opened for the user to enter their specific mapping for top…
  • John T
    0 John T over 2 years ago
    Hi Masa, it seems nobody else has a solution for you currently. I don't believe there is a way to merge padstacks for symbol pins.
    If you wish to merge via padstacks then you may use the via structure facility using the Route menu > Structures > Create via Structure. This creates an xml file in your design directory ( as per padpath). You can reuse these structures while connecting traces or you can replace existing through vias with the stacked blind or buried via structure. A description of this is presented in the Create structure window:
  • masamasa
    0 masamasa over 2 years ago in reply to John T
    thank u for ur response, john.
    i do not think this work as once a standard via structure is created, i would need to find where the stacked via locations are.
    i hope to find a way to find the stacked via locations as a stacked via report does not help.
    this is a new feature that i was not aware of and can use in a different situation, though.
    regards
    masa
  • DavidJHutchins
    +1 DavidJHutchins over 2 years ago in reply to masamasa
    The rules file "MergeStackedVias.txt" is opened for the user to enter their specific mapping for top via, bottom via & replacement via
    once the file is closed, it will prompt the user to select an rectangular area containing the vias to be replaced
    A summary of the replacements is output, below is an example:
    4 Vias selected, 2 StackedVias found, 2 Replaced, 0 Errorshttps://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/MergeStackedVias.zip
  • masamasa
    0 masamasa over 2 years ago in reply to DavidJHutchins
    thank u very much for the skill file, david.
    this is very useful.
    u r amazing!
    regards
    masa
