  3. When exporting the IDX file and importing to the mechanical...
  • State Suggested Answer
  • Answers 1
  • Views 5220
When exporting the IDX file and importing to the mechanical software such as solid works the 3D boxes are not visible
RohitRohan
RohitRohan over 1 year ago
Dear Community,
I am facing an issue related to the export of a PCB layout file from Allegro X Designer. In the 3D Canvas window of Allegro X Designer, I can view 3D boxes corresponding to the defined package heights, even though no 3D models are assigned to the layout. However, when I export the IDX file and import it into mechanical software such as SolidWorks, the 3D boxes do not appear.
I would appreciate it if someone could help me understand the potential cause of this issue. Am I possibly missing a step or configuration during the export or import process?
Looking forward to your insights and guidance.
Best regards,
Rohit Rohan
  • steve
    0 steve over 1 year ago
    Check the User Preferences for idx_place_bounds_top and _bttom and make sure that is the same subclass you are seeing in the 3dx canvas.
