  3. Display Pin Numbers on Component Pins - Display Via Net...
  • State Verified Answer
  • Replies 8
  • Answers 2
  • Views 8244
Display Pin Numbers on Component Pins - Display Via Net Names - in Allegro PCB Designer
BK20241203831
BK20241203831 over 1 year ago
In Allegro Viewer I am able to show pin numbers on the pins next to pin net names. I can't figure out how to do it in Allegro PCB Designer. I also need to show net names on vias.
This is what I am looking for in Allegro PCB Designer: Pin number next to pin name and net name on vias.
  • steve
    steve over 1 year ago in reply to BK20241203831 +1 verified
    Try Setup - Design Parameters and look on the Display tab at the bottom left.
  • steve
    Sorry should have said. This is using 24.1. It was a change made in the new release. All license levels - OrCAD X Std, Pro, Allegro X Artist, Designer, Designer Plus, Venture and Enterprise.
  • BK20241203831
    BK20241203831 over 1 year ago in reply to steve +1 verified
    Makes sense! Is 24.1 backward compatible? If I design with 24.1, would board files work in 22.1?
  • steve
    +1 steve over 1 year ago in reply to BK20241203831
  • BK20241203831
    +1 BK20241203831 over 1 year ago in reply to steve
  • steve
    Yes it is. Look under File - Export - Downrev Design. You can choose 17.4 (22.1) or 23.1. You will lose any 24.1 settings that have been applied but shouldn't be an issue.
