  3. Display Pin Numbers on Component Pins - Display Via Net...
  • State Verified Answer
  • Replies 8
  • Answers 2
  • Views 8243
Display Pin Numbers on Component Pins - Display Via Net Names - in Allegro PCB Designer
BK20241203831
BK20241203831 over 1 year ago
In Allegro Viewer I am able to show pin numbers on the pins next to pin net names. I can't figure out how to do it in Allegro PCB Designer. I also need to show net names on vias.
This is what I am looking for in Allegro PCB Designer: Pin number next to pin name and net name on vias.
  • steve
    steve over 1 year ago in reply to BK20241203831 +1 verified
    Try Setup - Design Parameters and look on the Display tab at the bottom left.
  • steve
    Sorry should have said. This is using 24.1. It was a change made in the new release. All license levels - OrCAD X Std, Pro, Allegro X Artist, Designer, Designer Plus, Venture and Enterprise.
  • BK20241203831
    BK20241203831 over 1 year ago in reply to steve +1 verified
    Makes sense! Is 24.1 backward compatible? If I design with 24.1, would board files work in 22.1?
  • VKPA
    0 VKPA over 1 year ago
    Try this to set the visibility of Pin_Number.
    display -> Color/Visibility -> Layers -> Geometry -> Package Geometry -> Check Pin_Number, then click on Apply.
    Thanks!
  • BK20241203831
    0 BK20241203831 over 1 year ago in reply to VKPA
    Thanks! When I turn that on, the text becomes too large and for dense ICs it becomes difficult to read. Is there a way to show pin numbers the same way Allegro Free Viewer does?
    Any ideas on showing net names on Vias?
  • steve
    +1 steve over 1 year ago in reply to BK20241203831
  • BK20241203831
    0 BK20241203831 over 1 year ago in reply to steve
    Interesting! I don't see what you have. What version of the tool do you have? I am on 22.1.
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to BK20241203831
    I see the same issue in SPB_23.1, I'm wondering if it's a license based
    However, in the new ( IMHO brain-dead ) free viewer you can control this from the Visibility Tab's Display settings for 'Other Labels'
