  3. fillet question
  • State Suggested Answer
  • Answers 1
  • Subscribers 167
  • Views 5187
fillet question
masamasa
masamasa over 1 year ago
hello
is there a way to retain the fillet even if the clines r shifted based on vias?
i see some designs that keep the fillets but i do not know where the fillet setting is located.
regards
masa
  • vidhyaparameswari
    vidhyaparameswari over 1 year ago +1
    Hi Masa, For fixing the teardrops and to avoid their removal, you can set the enable_fixed_fillets variable in the Route > Gloss category of User Preferences Editor. This can be accessed using the Setup…
  • vidhyaparameswari
    0 vidhyaparameswari over 1 year ago
    Hi Masa,
    For fixing the teardrops and to avoid their removal, you can set the enable_fixed_fillets variable in the Route > Gloss category of User Preferences Editor. This can be accessed using the Setup > User Preferences command.
    After setting this variable, it is required to restart the tool for adding new items for fixing and unfixing the teardrops in the Route > Teardrop / Tapered Trace menu.
    The new commands Fix Teardrop and Unfix Teardrop will be added.
    Select Route > Teardrop / Tapered Trace > Fix Teardrop and then select the teardrop that needs to be fixed. The following message will be displayed:
    Fixed status added to teardrop element Shape at x,y on subclass X
    The teardrops will not be changed dynamically when the traces are slided or moved. You need to unfix and delete the teardrops using Route > Teardrop / Tapered Trace > Unfix Teardrop to generate teardrops dynamically.
  • masamasa
    0 masamasa over 1 year ago in reply to vidhyaparameswari
    hello
    thank u for ur response.
    i am sorry that i did not explain enough.
    this is not what i am looking for unfortunately.
    i see a design where i slide a cline with a fillet around a via and the fillet also moves along with the cline.
    for ur setting, if i slide a cline, the fillet is fixed and stays the same location.
    i would not like to fix the fillet but move fillets along the cline motion.
     i do know that this exists but i do not know where the fillet setting is.
    regards
    masa
  • JCTEYSSIER0
    0 JCTEYSSIER0 over 1 year ago in reply to masamasa
    what you describe is Dynamic Filet.
    It is located in gloss parameters. BUT only with allegro license, not orcad license : dynamic filets are disable with orcad license. This is one of limitations.
  • AsbjornEdvalds
    0 AsbjornEdvalds over 1 year ago in reply to masamasa
    Hello Masa,
    Is this question the solution to your problem:
    community.cadence.com/.../dynamic-mode-disabled-gray-in-teardrops-parameters
