  3. Missing data in the stephdr file from ODB++ export
  • State Verified Answer
  • Views 4830
DavidAhl
DavidAhl over 1 year ago
Hi all,
We have an AOI machine supplier who says the stephdr file in our ODB++ export is incorrect.
So my question is if it is possilbe to configure this somehow. The Valor export wizard is very basic in its options and getting a support account at siemens seems complicated...
In the exported ODB++ file i have a stephdr file containing the following data:
UNITS=MM
X_DATUM=0
Y_DATUM=0
X_ORIGIN=0
Y_ORIGIN=0
TOP_ACTIVE=0
BOTTOM_ACTIVE=0
RIGHT_ACTIVE=0
LEFT_ACTIVE=0
AFFECTING_BOM=
AFFECTING_BOM_CHANGED=0
ID=5
our AOI supplier however says the following data also should be included in the same file whitch it is not:
STEP-REPEAT {
NAME=stp
X=0
Y=0
DX=0
DY=300
NX=1
NY=2
ANGLE=0
MIRROR=0
hope there are some ODB++ experts around here, Im sure there are:)
Im using Orcad PCB Designer Professional 23.1 and panelizing with Fab Panelization tool.
best regards everyone!
  • Gowtham P
    +1 Gowtham P over 1 year ago
    Hey DavidAhl ,
    I read the ODB++ manual provided by Siemens.
    From my understanding, these fields may be included only if your panel board contains step-and-repeat data (though I could be wrong on this). I believe this needs to be added in Valor.
    In Valor, you can view panelization information in the Step & Repeat Table dialog box.
    I recommend referring to the ODB++ User Guide / ODB++Design Format Specification for more details on this.
    Since ODB++ is a product of Siemens, their engineers would be the best point of contact for clarification.
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago
    When running the File>Export>ODB++ Inside translator
    on the first form are you setting the 'Show more options:'  to 'Yes' ?
    If so, on the next form are you setting the 'Use Panel Outline as profile:' to 'Yes' ?
    If so,  that changes the data extraction to include  PANEL/PANEL_OUTLINE to provide the step outline.
    I think if it finds data on that subclass what will enable the step&repeat data in the stephdr file.
    I am unable to verify this since I only have access to the 'tbx panelize' tool, not the Fab Panelization tool.
