  3. Display Your Know How: Thermal Relief
  • Replies 16
  • Subscribers 167
  • Views 16116
PCBTech
PCBTech over 1 year ago
Can you think of any design methods to enable the removal of thermal reliefs, such as shown in the following scenario?
Thermal relief traces
 Thermal reliefs are widely used to improve assembly soldering. However, after soldering is complete these copper features generally do not favour the electrical or thermal performance of the circuit. So what if we could remove them?
Simply suggest any ideas how we could do this in the comments below. Any alternatives and opinions are welcome!
  • digital1
    digital1 over 1 year ago in reply to PCBTech +1
    We use thermal reliefs to make it easier for the guy that has to rework the pcb.
  • excellon1
    excellon1 over 1 year ago in reply to PCBTech +1
    Full contact would not be superior for source thermals. If using full contact a use case exists that heat will be drawn away from the pin if using wave soldering as part of the assembly process. To put…
  • JCTEYSSIER0
    JCTEYSSIER0 over 1 year ago in reply to PCBTech +1
    Also for repair: is pin is full contact on all layer you have to heat up too much in order to remove solder and replace component: this can destroy the area.
  • JCTEYSSIER0
  • JCTEYSSIER0
    A full contact on several layers brings to heat up too much pcb in order to remove/replace a component and bring to pcb destruction localy
  • PCBTech
    PCBTech over 1 year ago in reply to excellon1
    Thanks for your input excellon1. These insights are greatly appreciated!
    In the image above used for this question, we show two different pin types: through-hole and surface. Focusing on the surface pins: do you see any other layout solution that would enable us to use full contact on the surface pins while encouraging good soldering? ( hint: imbalance)
    One key point we would like to highlight is that thermal reliefs on surface pins vs those on through-holes combat slightly different problems. The reason for their use is not exactly the same for each technology. Kudos goes to anyone that can think of what that difference is...
  • FaPb
    FaPb over 1 year ago
    You could change the narrow trace to a bigger shape and change both to full contact. This way both sides would have similar thermal properties and the risk of tombstoning would be reduced.
    Bonus note: If the component is a DFN type, the risk of tombstoning is not so big, because of reduced leverage on the terminals. Agree?
  • excellon1
    Hi PCBTech.
    Good questions. Looking at that particular design I would go with direct for both the smd and surface pins. From the soldering
    perspective you are looking at a really small copper surface area so soldering wont be any problem for even a budget rated IR oven.
    Basically because the copper surface area is tiny IR Ramp up will be fine.
    Best regards.
