  3. Display Your Know How: Thermal Relief
  • Replies 16
  • Subscribers 167
  • Views 16115
PCBTech
PCBTech over 1 year ago
Can you think of any design methods to enable the removal of thermal reliefs, such as shown in the following scenario?
Thermal relief traces
 Thermal reliefs are widely used to improve assembly soldering. However, after soldering is complete these copper features generally do not favour the electrical or thermal performance of the circuit. So what if we could remove them?
Simply suggest any ideas how we could do this in the comments below. Any alternatives and opinions are welcome!
  • digital1
    digital1 over 1 year ago in reply to PCBTech +1
    We use thermal reliefs to make it easier for the guy that has to rework the pcb.
  • excellon1
    excellon1 over 1 year ago in reply to PCBTech +1
    Full contact would not be superior for source thermals. If using full contact a use case exists that heat will be drawn away from the pin if using wave soldering as part of the assembly process. To put…
  • JCTEYSSIER0
    JCTEYSSIER0 over 1 year ago in reply to PCBTech +1
    Also for repair: is pin is full contact on all layer you have to heat up too much in order to remove solder and replace component: this can destroy the area.
  • excellon1
    Hi this is fairly easy to do within Orcad / Allegro. If using Allegro 17.2 and above you can change the pin properties so that the thermal relief is not needed, To do this select pins in the find filter then right click on the pin and choose property edit. Next assign the property of Dyn_Thermal_Con_Type and choose "none" for the layer you wish to remove the thermal from. Typically for thermal reliefs as in the picture there is a net associated with the pin so the net will still need to be connected on another layer.
    This only works for dynamic planes. If using Static planes there wont be dynamic thermals connecting to the pin.
    Best regards.
  • PCBTech
    PCBTech over 1 year ago in reply to excellon1
    Thanks for pointing this out excellon1 ! Yes it is easy to do manipulate the thermal relief property of pins in OrCAD and Allegro. But the question we would like to focus on is: should we?
    For electrical and thermal performance, the thermal type "Full_contact" is superior. This begs the question, why do we use thermal reliefs at all? Why not simply use full contact for shapes at all our pins?
    And what PCB design choices can we make to achieve this (if required) without compromising the automated assembly process; any suggestions?
  • digital1
  • excellon1
    Full contact would not be superior for source thermals. If using full contact a use case exists that heat will be drawn away from the pin if using wave soldering as part of the assembly process. To put it another way if the pin is the sink and it is connected directly to a moderate to large ground plane then that sink will suck heat away from the pin during soldering that can lead to poor soldering.
    For things like SMD based connectors it is possible to embed small vias within the pads so as to act as the connection to ground. Usually this is done on multi-layer boards. This very much depends on the connector / use case etc. Follow the data sheet !. In this particular case the vias would be direct connect to the planes. The vias basically provide a low inductance path to ground but have minimal effect on the soldering process.
    The best repeatable use case for Full_Contact use would be for vias.
    Best Regards.
  • PCBTech
    PCBTech over 1 year ago in reply to digital1
    Hi digital1, your comment points exactly to the reason why thermal reliefs are required for pins.
    We propose that thermal reliefs benefit soldering only; not electrical performance.
    The thermal benefit they bring to through-holes is to actually reduce thermal conductivity at each pin. Electrical current flow is also hindered by these narrow channels which can be important for high current circuits.
    If anyone can think of benefits of thermal reliefs other than for assembly, please let us know?
