  3. Display Your Know How: Thermal Relief
  • Replies 16
  • Subscribers 167
  • Views 16123
PCBTech
PCBTech over 1 year ago
Can you think of any design methods to enable the removal of thermal reliefs, such as shown in the following scenario?
Thermal relief traces
 Thermal reliefs are widely used to improve assembly soldering. However, after soldering is complete these copper features generally do not favour the electrical or thermal performance of the circuit. So what if we could remove them?
Simply suggest any ideas how we could do this in the comments below. Any alternatives and opinions are welcome!
  • digital1
    digital1 over 1 year ago in reply to PCBTech +1
    We use thermal reliefs to make it easier for the guy that has to rework the pcb.
  • excellon1
    excellon1 over 1 year ago in reply to PCBTech +1
    Full contact would not be superior for source thermals. If using full contact a use case exists that heat will be drawn away from the pin if using wave soldering as part of the assembly process. To put…
  • JCTEYSSIER0
    JCTEYSSIER0 over 1 year ago in reply to PCBTech +1
    Also for repair: is pin is full contact on all layer you have to heat up too much in order to remove solder and replace component: this can destroy the area.
  • excellon1
    excellon1 over 1 year ago in reply to excellon1
    Hi again PCBTech.
    One thought I forgot to include is a question.  On this small part of the design do thermals make any sense at all ?. I don't see that they do. As above the thing here is the really small copper area used. Direct connect is a far better option IMHO. Personally I typically favor
    max copper in any design.
    One other thought on this. Within Allegro the default for thermal relief is Orthogonal. It could very well be that the designer may not even been aware of the direct connect option. It looks like someone just poured a dynamic plane and the thermals appeared to tie the nets in to the small plane. :)  Kind of like pressing the go button, hey it looks good to me lol.
    Looking forward to your feedback.
    Best regards.
  • PCBTech
    PCBTech over 1 year ago in reply to excellon1
    Hi excellon1, we are loving this discussion. Thanks for all your inputs! You make a good point about the area of the copper. Yes the through-hole pin may not need thermal reliefs for this connection to the copper plane if this is the only copper layer connected. As in the case of through-holes, thermal reliefs are used to prevent heating escaping from the hole during soldering. This enables the local region to heat sufficiently such that an inter-metallic bond can be established between the solder and the metal surface of the inner hole.
    It should be noted that in this case, the heat source is the solder! However, for surface mount production, the solder is not fluid and so the heat energy is provided from the atmosphere, not the solder. Therefore surface mount pads use thermal reliefs for a different reason.
    Back to the topic of through-hole pins: In the first image, there are still some things that we cannot know. For example - how thick is this copper? Secondly, is this copper plane on the topside or the soldering side?
    (We shall assume this must be an outer layer due to the surface component nearby. However, embedded layer pads area possible using Allegro PCB Editor - but let's assume not in this case....)
    Do you have any thoughts if these factors should affect your decision about removing thermal reliefs?
    Also, do you know any other pin technology which could be used to avoid this entire dilemma?
  • PCBTech
    PCBTech over 1 year ago in reply to FaPb
    Gold star answer - thank you FalcomPeter !!
    Agreed, changing the narrow trace on the right side pin of the surface mount component will help to balance the thermal properties of this part which will help production. You have rightly pointed out that the issue of tombstoning is of concern for discrete component types. This phenomenon describes components that lift on one side due to a timing imbalance of soldering between different pins. The finished PCB may look something like a graveyard if lots of "tombstones" are sticking up in the air indicating a dead circuit due to these broken connections.
    It is caused when one surface pad heats up much faster than the other. The melted solder pulls on one side of the component due to surface tension and buoyancy. Without a counteractive pull from the other unmelted side, lightweight components will rise into the air. Videos of this phenomenon are available to view on public channels such as youtube.
    Question though: which side heats up quicker - the side with wider copper or the side with less copper? Remember the heat energy comes from the atmosphere.
    Do you have any thoughts on the through-hole discussion? Any insights would be very welcome. One point we would like to mention is the assembly technique known as "intrusive reflow", Some manufacturing engineers also name it "pin in paste".
  • PCBTech
    PCBTech over 1 year ago in reply to PCBTech
    Example of thermal balancing of smd pins with no thermal reliefs (full contact with copper planes)
  • PCBTech
    PCBTech over 1 year ago in reply to JCTEYSSIER0
    HI JCTEYSSIER0, thank you also for your inputs! It seems that these reasons also relate to manufacturing performance more than electrical performance. Would you agree?
    An interesting point that you have brought to mind, is if any designers ever consider blocking heat from travelling into a pcb due to electrically generated thermal output of components. It is conceivable that heat could be channelled away from the pcb by way of direct contact with the surface of a component with a heat sink for example. In that scenario, perhaps we can imagine the requirement to reduce thermal transfer through the pcb for heat dissipation.
