  3. Display Your Know How: Thermal Relief
  • Replies 16
  • Subscribers 167
  • Views 16132
PCBTech
PCBTech over 1 year ago
Can you think of any design methods to enable the removal of thermal reliefs, such as shown in the following scenario?
Thermal relief traces
 Thermal reliefs are widely used to improve assembly soldering. However, after soldering is complete these copper features generally do not favour the electrical or thermal performance of the circuit. So what if we could remove them?
Simply suggest any ideas how we could do this in the comments below. Any alternatives and opinions are welcome!
  • digital1
    digital1 over 1 year ago in reply to PCBTech +1
    We use thermal reliefs to make it easier for the guy that has to rework the pcb.
  • excellon1
    excellon1 over 1 year ago in reply to PCBTech +1
    Full contact would not be superior for source thermals. If using full contact a use case exists that heat will be drawn away from the pin if using wave soldering as part of the assembly process. To put…
  • JCTEYSSIER0
    JCTEYSSIER0 over 1 year ago in reply to PCBTech +1
    Also for repair: is pin is full contact on all layer you have to heat up too much in order to remove solder and replace component: this can destroy the area.
  • PCBTech
    And the final and 3rd solution we would like to suggest for this quandary is Press-fit-pins.
    This pin type is mechanically widened in the contact area; when inserted into a plated-hole, the side edges of the pin are mechanically compressed. This holds the pin into place without the need for any solder. The electrical contact is made by physical contact mating.
    This assembly technology requires no solder. Therefore, the need for thermal reliefs is removed completely and "full contact" can be used for copper shapes connected to this pin holes.
    If you have any alternative solutions or ideas, we would be very happy to hear your opinions.
