  3. Add a Geometry Layer
  • State Verified Answer
  • Answers 2
  • Views 5484
kevcon
kevcon over 1 year ago
I am trying to add a geometry layer to a PCB, there seems to be no clear way to do this, am I missing something?
  • DE202408202727
    DE202408202727 over 1 year ago +1 verified
    Setup/Subclasses/New Subclass
  • steve
    steve over 1 year ago in reply to kevcon +1 suggested
    There is an option to use the default "Allegro" menu if you want. Try Setup - User Preferences - UI - General and enable the orcad_use_legacy_menu then restart the tools.
  • DE202408202727
    +1 DE202408202727 over 1 year ago
  • kevcon
    0 kevcon over 1 year ago in reply to DE202408202727
    Wow, I would have never guessed that.
    Thank you.
    Just wondering if the menu system is different between versions, I am using 24.1 and it's
    Setup > More > Subclasses
  • DE202408202727
    0 DE202408202727 over 1 year ago in reply to kevcon
    I don't see that in 24.1. Do you have a custom menu?
  • steve
    0 steve over 1 year ago in reply to kevcon
    Its the difference between an OrCAD product and an Allegro one. the OrCAD products (Standard and Professional) have simplified menus. I have a menu comparison chart pdf but can't upload it.
  • kevcon
    0 kevcon over 1 year ago in reply to steve
    Yeah, that's one of the many things that is slightly annoying about OrCAD, the menus change instead of just greying out the item.
    I am using OrCAD X Pro.
    I noticed that the menu/submenus are different for the same item depending on if you are in PCB or Footprint editor.
