  3. Removing Soldermask from Backdrill Vias
  • State Verified Answer
  • Subscribers 166
  • Views 4512
CP202407234840
CP202407234840 over 1 year ago
I'm trying to remove the Soldermask_Bottom from my back drilled vias that are on my design. Right now, I'm attempting to do:
Select via > modify design padstack > single instance. Once in the padstack editor, I'm changing the backdrill_soldermask to "None":
After saving I get some warnings and upon exiting, nothing is changed. The last warning is:
"Default backdrill data from design will not be saved in pad file"
Is there a different way to tent these vias on the back side?
  • avant
    avant over 1 year ago +1 verified
    Open, modify, and save the pad stack under a new name. Replace affected pad stacks (single instance, one at a time) with the new pad stack. If this is too time consuming, ask someone here to create…
  • VishnuVRD
    0 VishnuVRD over 1 year ago
    try to change in library file and then update padstacks, see if that works
  • avant
    +1 avant over 1 year ago
    If this is too time consuming, ask someone here to create a script to do it automatically.
  • CP202407234840
    +1 CP202407234840 over 1 year ago in reply to avant
    This is what I ended up doing. Thanks!
