  3. How can I assign a net to an etch arc in Cadence Allegro...
  • State Suggested Answer
  • Answers 1
  • Views 4096
How can I assign a net to an etch arc in Cadence Allegro 17.4?
KD202502275710
KD202502275710 over 1 year ago
I'm working in Allegro 17.4 and need to assign a net to circular etch arcs. In Altium, this is simple, but I can't find a way to do it in Allegro. I tried starting the arc from copper with the desired net, but it didn’t inherit it. How can I assign a net to an existing arc, or how are nets assigned to etch arcs in Allegro?
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago
    Have you tried creating the arc as part of a cline by using 'add connect' with the Line lock Options value from 'Line' to 'Arc', then route from a pin or via?
  • avant
    0 avant over 1 year ago
    The line must be connected to a via or pin to inherit a net.
