  3. Match Track Lengths Across Multiple Layers
  • State Suggested Answer
  • Replies 7
  • Answers 1
  • Subscribers 166
  • Views 7146
PS202410214615
PS202410214615 over 1 year ago
Hi everyone,
I’m working with Allegro X Editor 2023 and need help matching the track lengths for a few nets. These nets span across three different layers, and simply matching the total track length is not sufficient. I want to ensure that the signal timing is controlled across all layers, so I need to match the track length on each layer individually.
I've tried using the "Total Length" and "Relative Propagation Delay Length" features, but these methods are not giving the desired results, as they take the entire length into account rather than each individual layer.
Can anyone guide me on how to achieve this?
  • JCTEYSSIER0
    JCTEYSSIER0 over 1 year ago in reply to PS202410214615 +1 suggested
    So you have to constraint the delay using ns or ps insteat of length (mm or mils): doing so if your stackup is correctly defined it will solve your problem; Z delay enabled take into account the delay…
  • Robert Finley
    0 Robert Finley over 1 year ago in reply to JCTEYSSIER0
    I believe an SI simulation giving you an eye diagram will help.
    A significant change in impedance along any portion of the net will cause both changes in propagation speed and result in signal reflections.  I.E. your signal transition will get there in time but the logic/voltage levels won't work.
    I believe the only cause for propagation to be noticeably different between signal layers is stackup config related.
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago
    Hi PS202410214615!
    you can refer this code.
    view = nil
    axlCmdRegister("total_length_net" `total_length_net)
    (defun total_length_net ()
    axlClearSelSet()
    axlSetFindFilter(?enabled '(noall NETS) ?onButtons '(noall ALL))
    mypopup = axlUIPopupDefine(nil (list (list "Done" 'axlFinishEnterFun) (list "Cancel" 'axlCancelEnterFun)))
    axlUIPopupSet( mypopup)
    while(axlSelect(?prompt "Please select an element...")
    STT =0
    if(view != nil then axlUIWClose(view))
    Input_List = axlGetSelSet()
    axlClearSelSet()
    Out_File = outfile("./total_length_net.log" "w")
    foreach(net Input_List
    pins = axlPinsOfNet(net 'pin)
    STT++
    if(length(pins) == 2 then
    parent = car(pins)->parent
    fprintf(Out_File "%-5d %s.%s %s.%s %-10s\n" STT parent->refdes car(pins)->number parent->refdes cadr(pins)->number net->name)
    path = axlFindPath(car(pins) cadr(pins))
    foreach(item path
    if(item->objType == "path" then
    fprintf(Out_File "\t%-10s %-10.2f\n" cadr(parseString(item->layer "/")) axlDBGetLength(item))
    close(Out_File)
    printf("Total: %n Found\n" STT)
    view= axlUIViewFileCreate("total_length_net.log", " " nil)
    Best Regards.
    HoangKhoi .
