  3. Match Track Lengths Across Multiple Layers
  • State Suggested Answer
  • Replies 7
  • Answers 1
  • Subscribers 166
  • Views 7145
PS202410214615
PS202410214615 over 1 year ago
Hi everyone,
I’m working with Allegro X Editor 2023 and need help matching the track lengths for a few nets. These nets span across three different layers, and simply matching the total track length is not sufficient. I want to ensure that the signal timing is controlled across all layers, so I need to match the track length on each layer individually.
I've tried using the "Total Length" and "Relative Propagation Delay Length" features, but these methods are not giving the desired results, as they take the entire length into account rather than each individual layer.
Can anyone guide me on how to achieve this?
  • JCTEYSSIER0
    JCTEYSSIER0 over 1 year ago in reply to PS202410214615 +1 suggested
    So you have to constraint the delay using ns or ps insteat of length (mm or mils): doing so if your stackup is correctly defined it will solve your problem; Z delay enabled take into account the delay…
  • JCTEYSSIER0
    0 JCTEYSSIER0 over 1 year ago
    Sound like you wish to match length between components pin and not full net?
    So you have to create pin pairs and constraint pin pairs instead of net.
    Net exemple:
    U1.1 U2.3 U4.11
    second net
    U1.2 U2.5 U4.6 R55.1
    if you want to match U1.1 to U2.3 with U1.2 to U2.5 you have to create two pins pairs with theses points and then put them into a matchgroup,, not the nets
  • PS202410214615
    0 PS202410214615 over 1 year ago in reply to JCTEYSSIER0
    I appreciate the responses, no, i need full length.
    I have simple pin-to-pin connections like U1.1 to R263.1, U1.5 to R302.1, U1.56 to R402.1, and so on. These are sequential IC signals, and due to space constraints and the use of SMD components with vias, the tracks change layers.
    My goal is to match the track length on each layer, not just the total length. Since these signals need to be driven in a timely manner to enable or disable as required, it's crucial that the track length is consistent on each layer to control the signal timing properly.
    I've tried using "Total Length" and "Relative Propagation Delay Length," but they don't give the desired results because they calculate the entire length across all layers, not per layer.
    I’ve attached a simple image showing the connections, where U1 is the source, R* is the receiver, and the vias are represented as circles. The different colours represent different layers.
  • JCTEYSSIER0
    0 JCTEYSSIER0 over 1 year ago in reply to PS202410214615
    Does enabling Z delay solve you issue? So it take into account the length between layers.
    Or your problem is different propagation delay on different layers ? On outer layers the speed is a little faster than inner layers. If so, do not constraint length but delay.
    I do not think it is possible (maybe, but not easy: never have such case; maybe with a skill routine ) to match length per layer
  • PS202410214615
    That’s exactly what I need.
    If you have any ideas, shortcuts, techniques or skill
    that could assist in resolving this issue, please share. In the meantime, I will explore enabling the Z delay to see if it helps.
    thanks a lot
  • JCTEYSSIER0
    So you have to constraint the delay using ns or ps insteat of length (mm or mils): doing so if your stackup is correctly defined it will solve your problem; Z delay enabled take into account the delay in via introduced by layer change.
    Be aslo aware of pin delay if applicable in your case
    See Steve note:
     https://community.cadence.com/cadence_technology_forums/pcb-design/f/pcb-design/46689/propagation-delay-delta-tolerance-value-in-mils
