  3. Placement Grid not working
  • State Suggested Answer
  • Answers 1
  • Views 4138
VishnuVRD
VishnuVRD over 1 year ago
I'm trying to place components with 2mm grid size but it's not working. Routing is working fine with 2mm grid, but when I move components it's not working. I set 2mmgrid size using Setup -> Design Parameters -> Display -> Setup grids on Etch and Non-Etch layers. It was working fine until yesterday, not sure what happened.
Thank you.
  • steve
    0 steve over 1 year ago
    This is usually dependant on the Application mode you are in (or command). Try changing the application mode to Placement Edit and that should use the Non-Etch grid. There are lots of ways to change this - right click on the screen - Application Mode - Placement or look in the bottom right hand corner of the screen and yiou should see a mode which can be changed.
