  3. How select only pins, but highlight associated net?
  • State Suggested Answer
  • Answers 1
  • Views 4784
SO202503141427
SO202503141427 over 1 year ago
In the design object find filter, I would like to enable only "pins". Then when I select a pin, I would like the associated net to be highlighted.
I can approximate this by enabling both "pins" and "nets" in the find filter - but then I also can select nets that are routed under or near the pin (and I am trying to avoid those).
I'll try to attach an image if the post will let me ...
  • JuanCR
    0 JuanCR over 1 year ago
    Hi SO202503141427 . I would suggest (not enabling both pins and nets in the find filter but) to use a combination of the "Find by Name" (say to search for the net name) and the find filter set to Pins only.
    Alternatively, you can also write a custom script in SKILL that takes a selected pin's dbid, extracts its net name and selects all pins belonging to this net.
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to JuanCR
    the attached zip file contains a simple skill script for highlighting a net by the pin ( as a ref.pin or by pick )
    entries from the journal file:
    skill 'load "hilite_by_pin.il"'
    hilite_by_pin
    hilite_by_pin J1.4
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/hilite_5F00_by_5F00_pin.zip
