  3. Display Your Know How: Decoupling Capacitor
  • Replies 10
  • Views 7097
PCBTech
PCBTech over 1 year ago
The golden rule of decoupling capacitor placement is to minimize the distance between the IC’s voltage pin and the capacitor.
What about the routing of the capacitor to POWER and GROUND pins/planes!!
Which among the above decoupling capacitor routing configurations is better?
Any improvements that can be done?
Simply answer by letter or include any reason to support your answer. Alternatives and opinions are welcome!
  • excellon1
    excellon1 over 1 year ago in reply to PCBTech
    Hi PCBTech.
    So on the Pictures A, B ,C are OK. pic D has etch that is too small for the trace. Some considerations. The best connection off the pin to the pad of the cap should be as wide as possible so as to minimize inductance. The other consideration is how much power that pin is drawing. One would want to take into consideration the current. Typically the vias will connect to a plane or micro plane if they are used for power. Configure the vias so that they are direct connect to the plane. No waggon wheels so as to minimize inductance.
    On PIC B, That via is too close to the BGA pin, A, C look better. Depending on space under the BGA one may have to make a choice between perfect and good enough !. Depending on the pitch of the BGA one can also rotate the caps so they are at 45 degrees which can allow to get the cap very close to the pin if needed.
    Because the distances are so small between the BGA Pin and the cap, via connections,  the dominating factor electrically will be the capacitor used and how effective that capacitor really is at reducing noise at the BGA Pin.
    Last thing, personal preference is to use rounded rectangles for the capacitor pads. Not rectangles. There are 2 combinations not shown in the pictures, wonder what they could might be ?.
    Best Regards.
  • JCTEYSSIER0
    JCTEYSSIER0 over 1 year ago in reply to DavidJHutchins
    Same engineers here.
    For me,  pin->capacitor->via is usefull for analog circuit.
  • JCTEYSSIER0
    JCTEYSSIER0 over 1 year ago in reply to JCTEYSSIER0
    Tip: for numeric, ideal is to have loop's area between power and ground the smaller as possible.For bga, unfortunately no choice but to plca capacitor on opposite side of bga. For others, i take into account the pcb thickness (already use 5mm thick!)  to know the real loop area.
  • PCBTech
    PCBTech over 1 year ago in reply to DavidJHutchins
    Thank you, DavidJHutchins, for sharing your expertise. I completely concur with your point.
    Decoupling capacitors, strategically placed between the power supply pins and ground pins of an IC, provide a low-impedance pathway for current during switching transients. This effectively mitigates voltage fluctuations on both the power supply and ground lines.
    Do you have any additional thoughts or insights to share on this topic?
  • John T
    John T over 1 year ago
    In the early years senior hardware engineers were advising me to place capacitors directly at the signal receiver pin tied to ground. This was explained to be "filtering out" high frequency noise from the signal. So the cap was acting as a short to ground for higher frequencies.
    But later on, SI experts were advising that capacitors act as a source of voltage when there is a supply drop due to high frequency demands. The capacitors then temporarily supply voltage for quick short bursts. So which is it, a short for filtering or a voltage supply?
